Offline routing is now available in Kurviger:
- Route planning: all routing calculations fallback to offline routing profile when there is no online connection.
- Navigation: offline partial rerouting is calculated from user’s location to the route (based on rerouting mode).
Offline reroute section joins the rest of the existing curvy route and navigation continues on the merged route.
Every other “rerouting” nav activity should work similarly offline, like avoid road block or skip next waypoint.
Offline routing requires the presence of offline graphs (folders of routing data) for each region.
There are available offline graphs for each region in our new download server (like offline maps).
Unpack the downloaded zip in mobile device and load the graph via application’s routing menu.
Likewise the Mapsforge server also provides worldwide offline graphs.
You can also create offline routing graphs with desktop Cruiser:
- Download any osm/pbf file from Geofabrik for your region.
- Select “Speed mode” or “Flexible mode” and check the “Car” in the menu “Routing | Graph options”.
“Speed mode” offers faster offline routing on mobile, though graph creation is slower on desktop. - Create the graph via menu “Routing | Create graph”: select any downloaded osm/pbf file and then an empty folder for graph output.
Depending on region size and available memory, can increase Java heap size (Xmx) in bat / sh files and run Cruiser with them. - Move the created graph folder in mobile device and load the graph via application’s routing menu.
Offline routing currently has the following properties:
- Offline routing calculations use the fastest profile (no curvy algorithms).
If Robin can implement them to work offline on mobile, then I can add them. - No straightforward cross border offline routing yet (limitation of library).
Depends also on input osm/pbf bounds (Geofabrik usually provides countries).
Or use special region wide graphs: Alps, DACH (Germany+Austria+Switzerland). - I’ll also add BRouter offline routing, which doesn’t have these limitations.
Available in menu “Routing | Open data”.
