kann ich die Tour auch einfach ausdrucken?
Hello, is there a way to print a PDF that includes a visual of the map and turn-by-turn directions as well for the full route?
I read the recommendation to take a screenshot of the map in the documentation; however, this is not a very clean solution and would not include the full turn-by-turn directions.
Iād love for there to be a way to print a clear and concise overview of routes, including a map and turn-by-turn, if possible.
Thank you!
Hello @lstogsdill,
As you already read correctly in the Knowledge Base, there is no other way to print the map at the moment. What you can do is Export a Roadbook. You find that option on the Kurviger Website in the planning view ā three-dot-menu ā show turn instructions ā export road book.
The Roadbook is helpful. Is it only possible to export as a CSV file, or is exporting as a PDF file possible somehow?
If you got a CSV file you can import it into Excel (or something like that) and create a PDF file out of it.
Link = https://kurv.gr/GRaqT
CSV = Muenchen - Rottweil.zip (1,1 KB)
PDF = RoadBook.pdf (221,8 KB)
