BMW Wonderwheel with Kurviger is not working
BMW 1300 GS built 2025, BMW Wonderwheel/CDMI with carpe Iter tablet Android 11, NGH actual,Locus and Calimoto works fine, Kurviger Version 3.6 X doesn´t allow zoom anymore.
Any ideas, rather than switching to Calimoto?
Check out if the feedback and instructions from Carpe Iter in this post can help you slove the issue:
I am sorry, does this I made a mistake, if so how can I fix it. .My friends are facing the same problem. Anyway if there is no solution I will switch to Calimoto, there it works at least for the time being.
You surely did not make a mistake.
Have you read the link, @t00thl355 has posted? This the answer from Carpe iter. There was a minor change in the button mapping in Kurviger and Carpe Iter made correspinding changes. With the many eyes of your friends, you surely get it up and running.
And if not, in the post linked above, there is a link to Carpe Iter trouble ticket system. Submit a ticket there - that is probably the quickest way to a competent helper.
Thanks, everything works fine with calimoto.
You lost not only one customer, also my friends are astonished about your not helping reply. Have a great day
Wolfgang and friends
Can you tell what you have tried, which app from Carpe Iter you have installed (NGH, and uninstalled old one), if you followed the instructions from Carpe Iter (link above), and perhaps even created a ticket as adviced? At which point you got stuck?
You did not respond to our hints, then hard words. Honest, but I am not sure, if it is fair. We have no access to your devices.
Check here: Video from Carpe Iter (4 weeks ago), seems to work, as far as I understand.
Thorsten,
I/we followed the hints which were given. All was deinstalled and NGH installed. It didn’t work out.Anyway I will not spend more time on it. As you mentioned, it must be on carpe iters side, which is nonsense, because something changed on Kurviger side.The only reason why I bought carpe iter was Kurviger and the new BMW system was and is crap. Anyway calimoto works for now. I wished you would have put more efforts in it to solve it, rather than putting it on carpe iters plate
Wolfgang
Toffel has tried to help you to his best knowledge.
He is a just a regular customer of Kurviger.
