Cannot rename saved POIs in Favorites
I noticed a small difference in behaviour between custom waypoints and existing POIs when saving them as favourites.
If I create a new waypoint, I can give it a custom name before saving it to favourites. However, if I add an existing POI from the map (for example a BP fuel station), it is saved with the original POI name and there doesn’t appear to be an option to rename it.
This becomes a little confusing when looking at the favourites list, because several entries may simply appear as “BP”, and it’s difficult to tell which location is which without opening each one.
Is there currently a way to rename a saved POI in favourites that I may be missing?
If not, allowing custom names for saved POIs (similar to custom waypoints) could make favourites much easier to organise.
Cheers.
Here is already a discussion and explanation. At the top you can vote for this planned feature.
Most common workaroud is to place an additional point, then you can give this new point a name.
Thank you for the tip :+1:
