# Closed Roads
**URL:** <https://forum.kurviger.com/t/closed-roads/4220>\
**Category:** Route planning\
**Tags:** new-feature, routing, idea\
**Created:** [September 11, 2020, 12:34pm UTC](https://forum.kurviger.com/t/closed-roads/4220 "2020-09-11T12:34:10Z")\
**Post date:** [September 11, 2020, 12:41pm UTC](https://forum.kurviger.com/t/closed-roads/4220/2 "2020-09-11T12:41:05Z")
Avoid roadblock is already available in application:
(press top-left navigation panel)
> [@App: Avoid roadblock](https://forum.kurviger.com/t/app-avoid-roadblock/186):
> Hi, im Mode Navigation hat man ein Symbol für Einstellungen, was einen auf die allg. Einstellungen führt. Viele dieser Einstellungen sind während der Navigation nicht relevant. Es wäre mein Vorschlag, im Mode Navigation diesen button kontextsensitiv zu gestalten. Dann könnten Einstellungen navigationsrelevant aufgerufen werden. z.B. Einstellungen allg. (so wie jetzt) Tag/Nacht Umschaltung Route gesperrt Rerouting On/OFF Das könnte man dann auch mit großen buttons machen, die sich mit Hands…
If mean to set block areas in route planning, that is programmed for the future:
(but it loads the server, so we need to think how it can be offered)
> [@Website: Block road access in route planning](https://forum.kurviger.com/t/website-block-road-access-in-route-planning/2421):
> Dear all, I need some more explanation if I’ve understood the new function of “closed roads” (Baustelle 500m etc.) correctly. For sure I’ve understood if I’m on a tour and reaches a closed road I’m able to acitivate this “closed roads” button via the arrow on the left /upper side. But I have to be directly there? I’m not able to change the route and use this function in advance? Today this happened: I wanted to plan a new route in the App for a short tour tomorrow. Normally I’m planning on t…
> [@App: Block road access in route planning](https://forum.kurviger.com/t/app-block-road-access-in-route-planning/2817):
> For reference see: [https://forum.kurviger.com/t/website-block-road-access-in-route-planning/2421](https://forum.kurviger.com/t/website-block-road-access-in-route-planning/2421)
_[View the full topic](https://forum.kurviger.com/t/closed-roads/4220)._
