You’re right, last sentence was irritating; wamted to express something else, but not clearly enough - let’s just drop it; it’s not necessary anyway …
Difference exists in map orientation:
- Either map has north always upwards and location arrow rotates
- Or map rotates and location arrow remains always upwards
In both cases the compass follows the map north and the label presents the location direction.
Ok, next draft for the entry for documentation:
Compass and label of geografic direction
In the left top corner you find a compass symbol, and, if you have confirmed this option (Settings - Map - Bearing) additionally a label below with the usual abbreviations for geografic directions (e.g. NE).
The arrow of the compass symbol shows, as every compass, the direction to the geografic north on the shown map.
The label below (letters of compass directions) shows the compass bearing, i.e. direction of current movement.
A tap on the compass symbol let you choose:
a) Manual:
Top of map remains directed to north
(you can rotate map with two fingers, but 2nd tap rotates map back to top = north),
b) GPS:
Orientation of map follows current direction of movement (i.e. the location arrow remains upwards),
c) Compass (2D or 3D):
[Me I never use these: What are there advantages?? Is there already an entry about these options in docu? Did not find any]_
You should choose
(a), if you prefer to stay orientated about geografic north always while moving - then the label informs you about the geografic direction of your current movement (and the location arrow rotates too accordingly),
(b), if you prefer to see always the course of the route in front of you towards the top of the map - then the compass informs you about the direction of geografic north of course rotates).
(c )*, if … [??? - see above!]
Ooops - even more complicated … ![]()
We have to include a case discrimination:
A Pure map mode without navigation (then it is like described above)
B Navigation mode (then tapping the compass toggles directly between options a and b)
Right?? (Getting complex …
Oder
… zeigt die Richtung in die sie sich bewegen.
(Prefer to write in English first - we may translate to good and clear German later, but want to separate these two steps …)
… and we still have a third mode:
C Following mode with or without navigation: Then again it is like mode A.
Right?
(Did I really really confirm to write an entry for documenation???) ![]()
Very nice!
With those orientation modes the map rotates and tilts based on device compass readings, instead of GPS sensor.
In navigation, when tap the compass, the map rotation is turned on / off.
Ok, got this, thx. As said, never use(d) this.
Yes, will add this, thx - it’s the same meaning.
Also as discussed here in next version the map orientation options will be enriched with GPS 2D and GPS 3D modes. ![]()
Ooooh noooo … ![]()
Whats the advantage of using the device compass instead of GPS?
Compass has usually the disadvantage of erroneous readings due to device sensor quality without calibration and being affected by near electronic equipment.
GPS orientation needs movement, while compass can provide it while standing.
Ich schreibe lieber auf Deutsch und überlasse die Übersetzung den Profis.
Danke
Wenn du mein englisches Original automatisch auf Deutsch übersetzen lässt, macht es keinen Sinn, dann DIESE deutsche Version zu redigieren …
Die automatisierten Übersetzungen von Google sind nicht gut genug! Das sieht man auch an deiner deutschen Übersetzung “Bitte schreiben Sie zuerst auf Englisch - wir können später gut und klar Deutsch übersetzen, möchten aber diese beiden Schritte trennen …” meines englischen Kommentars, der eigentlich hieß: “Ich (!) bevorzuge es, zuerst in Englisch zu schreiben - das können wir später in gutes und klares Deutsch übersetzen, aber ich (!) würde diese beiden Schritte gerne voneinander trennen …”
Deswegen bitte erst mal nur Änderungswünsche auf Englisch! Ok?
Ok - got it! Thx!
NEXT VERSION: ![]()
The arrow of the compass symbol shows, as every compass, the direction to the geografic north of the shown map.
Using is different in different modes of Kurviger:
A “Pure map mode” without navigation OR “Following mode” with or without navigation:
Tapping the compass toggles directly between turning on and turning off map rotation (hint appears in a bubble):
1) Map rotation: Off:
(you can rotate the map with two fingers, but after 2 (!) taps the map rotates back to top = north),
2) Map rotation: On:
Orientation of map follows current direction of movement (i.e. the location arrow remains upwards),_
You should choose
(1), if you prefer to stay orientated about geografic north always while moving - then the label informs you about the geografic direction of your current movement (and the location arrow rotates too accordingly),
(2), if you prefer to see always the course of the route in front of you towards the top of the map - then the compass informs you about the direction of geografic north of course rotates).
B “Navigation mode”:
1) Manual:
2) GPS (2D or 3D*):
3) Compass (2D or 3D):
You should choose
(2), if you prefer to see always the course of the route in front of you towards the top of the map - then the compass informs you about the direction of geografic north of course rotates),
(3), if you want to get information about directions without moving, because the device’s compass does not need movement; but this may have the disadvantage of erroneous readings due to device sensor quality without calibration and being affected by near electronic equipment.
*) Will be implemented soon.
@diesel6876: Bitte lass uns erst mal beim Englischen bleiben, sonst kann @devemux86 nicht kritisch folgen, und er muss den Text ja sachlich bestätigen! @boldtrn wird das dann sicherlich noch mal sprachlich prüfen, und wenn der Beitrag erst mal inhaltlich (!) steht, können wir daraus eine gute deutsche Übersetzung machen - ok?
Bezieht sich das auf dieses Thema, oder darf ich genell nicht mehr auf Deusch im Forum schreiben.
Gruß
Neiiiiiiin - natürlich nur hier, wo es um die Vorbereitung eines Beitrags für die Dokumentation geht!! ![]()
Ansonsten, wie schon mehrfach betont, sind alle Sprachen zugelassen!! ![]()
