Do routes stay static when shared if route recalculation is turned off?
If I create a route and share it with someone via link, will the route remain identical down to the turn-by-turn when the sharee opens the route (assuming the sharee has recalculation set to off)? Or is there any chance the turn-by-turn recalculates when the sharee opens the route link?
Hi @lstogsdill,
If you share a route via link the route is the exact same as yours, as long as both of you don’t change anything. However, if you make changes to a shared route, your friend has to open and load the route again for it to be up-to-date (I assume we talk about Cloud Sharing).
