# Downloadarea for maps
**URL:** <https://forum.kurviger.com/t/downloadarea-for-maps/10406>\
**Category:** App\
**Tags:** beta\
**Created:** [February 28, 2023, 11:59am UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406 "2023-02-28T11:59:10Z")\
**Posts on this page:** 12\
**Page:** 1
<div class="post-metadata">
**Author:** ![Karl-Heinz\_Walter](https://forum.kurviger.com/user_avatar/forum.kurviger.com/karl-heinz_walter/32/9577_2.png) [@Karl-Heinz\_Walter](https://forum.kurviger.com/u/Karl-Heinz_Walter)\
**Post date:** [February 28, 2023, 11:59am UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/1 "2023-02-28T11:59:10Z")
</div>
Where are the download cards saved in beta version 3?
[image] as possible]
Device: samsung - SM-G985F - Android: 13 - WebView: 110.0.5481.65
App-Version: 3.0.4 - 572
Screen: 412 x 915 px - 3.5dppx
**Author:** ![Viola](https://forum.kurviger.com/user_avatar/forum.kurviger.com/viola/32/12413_2.png) [@Viola](https://forum.kurviger.com/u/Viola)\
**Post date:** [February 28, 2023, 12:29pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/2 "2023-02-28T12:29:31Z")
</div>
Take a look into this thread …
> [@Offline Planung neue App Version](https://forum.kurviger.com/t/offline-planung-neue-app-version/10114/9):
> Das passiert momentan im Hintergrund und ist für den Nutzer nicht sichtbar. Ein nicht ganz so ideales Verfahren, da ich selbst gern sehe, was aktiv im “Download-Verzeichnis” passiert. wink
**Post date:** [February 28, 2023, 6:53pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/3 "2023-02-28T18:53:56Z")
</div>
Ok. This means that the memory fills up little by little without me being able to do anything about it.
Will the download maps at least be deleted if I uninstall Kurviger 3?
Das heißt, dass sich der Speicher so nach und nach füllt, ohne dass ich etwas dagegen machen kann.
Werden die Downloadkarten wenigstens gelöscht, wenn ich Kurviger 3 deinstalliere?
**Post date:** [March 1, 2023, 4:36pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/4 "2023-03-01T16:36:25Z")
</div>
> [@Karl-Heinz\_Walter](#):
No, it won’t grow unlimited, just up to a certain point (10 routes). Right now I think it will be really hard to get over 1GB (unless you are planning multiple tours across the globe)
Yes sure.
**Author:** ![anon50555842](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/a/e5b9ba/32.png) [@anon50555842](https://forum.kurviger.com/u/anon50555842)\
**Post date:** [March 1, 2023, 4:51pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/5 "2023-03-01T16:51:49Z")
</div>
Wiese kann man mit Kurviger3 nicht auf Karten von OpenAndroMaps oder das Kurviger1/2-Verzeichnis verlinken/zugreifen.
**Post date:** [March 1, 2023, 5:10pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/6 "2023-03-01T17:10:07Z")
</div>
> [@anon50555842](#):
Die neue Kurviger App verwendet ein anderes Dateiformat.
**Post date:** [March 1, 2023, 5:42pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/7 "2023-03-01T17:42:49Z")
</div>
Das ist sehr, sehr schlecht und ein Grund bei Kurviger1 zu bleiben.
**Author:** ![rumbrummer](https://forum.kurviger.com/user_avatar/forum.kurviger.com/rumbrummer/32/113_2.png) [@rumbrummer](https://forum.kurviger.com/u/rumbrummer)\
**Post date:** [March 2, 2023, 6:23am UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/8 "2023-03-02T06:23:00Z")
</div>
Etwas Geduld, lass den Entwicklern eun wenig Zeit.
Ich lade auch lieber vorab einen von mir definierten Kartenbereich runter, denke aber, dass das mittel- bis langfristig kommt:
> [@K3 Offline map local destination, Route different color for sections](https://forum.kurviger.com/t/k3-offline-map-local-destination-route-different-color-for-sections/10060/4):
> I am not 100% sure what Orux is using for maps, but K3 is not using file based offline maps anymore. Currently, you can download maps for a route. In the future it should be possible to also download maps for arbitrary areas. This works with K3 during the route planning mode already. You can set this in the settings under route details. This is not yet available for the navigation.
**Author:** ![Spilles](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/s/d9b06d/32.png) [@Spilles](https://forum.kurviger.com/u/Spilles)\
**Post date:** [June 17, 2023, 3:45pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/9 "2023-06-17T15:45:49Z")
</div>
Mich würde mal interessieren, was mit den Karten passiert, die man beim Starten der Navigation herunterladen kann. Welche Datenmenge ist das, wo wird sie gespeichert und wie lange bleiben die erhalten?
Ist irgendwann mein Gerätespeicher voll, wenn ich für eine Rundreise sagen wir mal 5 ziemlich verschiedene Karten downloade?
Danke und Gruß: Spilles
**Post date:** [June 17, 2023, 3:56pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/10 "2023-06-17T15:56:12Z")
</div>
@Spilles
… in diesem Beitrag findest Du die Antworten auf deine Fragen …
**Post date:** [June 17, 2023, 4:05pm UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/11 "2023-06-17T16:05:18Z")
</div>
@Viola
Danke!
Wär aber trotzdem interessiert zu erfahren, wo die Daten hingehen. Ich habe nämlich nicht mehr viel Platz auf meinem Gerätespeicher und schon dauernd Probleme. Auf der SD-Karte wäre noch mehr frei…
**Author:** ![DRose](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/d/bbe5ce/32.png) [@DRose](https://forum.kurviger.com/u/DRose)\
**Post date:** [June 18, 2023, 6:18am UTC](https://forum.kurviger.com/t/downloadarea-for-maps/10406/12 "2023-06-18T06:18:19Z")
</div>
Unter Android kann man Apps bzw. deren Arbeitsspeicher auf die SD-Karte verlagern.
z.B. mit diesen Aufrufen : Einstellungen/Apps/Kurviger/Speicher/verwendeten Speicher/ändern/sd-card.
Gilt für Android 11, bei den anderen Versionen ist es ähnlich
