# Export does not match
**URL:** <https://forum.kurviger.com/t/export-does-not-match/8452>\
**Category:** Website\
**Created:** [June 5, 2022, 9:14am UTC](https://forum.kurviger.com/t/export-does-not-match/8452 "2022-06-05T09:14:11Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Akki](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/a/b9e5f3/32.png) [@Akki](https://forum.kurviger.com/u/Akki)\
**Post date:** [June 5, 2022, 9:14am UTC](https://forum.kurviger.com/t/export-does-not-match/8452/1 "2022-06-05T09:14:11Z")
</div>
Illegal GPX input
An export of data could not be imported again.
Naoussa-Stomio in Greece
Best regards,
Axel
**Post date:** [June 5, 2022, 9:19am UTC](https://forum.kurviger.com/t/export-does-not-match/8452/2 "2022-06-05T09:19:50Z")
</div>
Do you import a GPX file in the website and it does not work?
Where did you find or export the GPX file?
Please provide the GPX file, so that others can examine the report.
**Post date:** [June 5, 2022, 11:16am UTC](https://forum.kurviger.com/t/export-does-not-match/8452/3 "2022-06-05T11:16:56Z")
</div>
See also here, in case it is related:
> [@Problem with overwrite in export](https://forum.kurviger.com/t/problem-with-overwrite-in-export/7987):
> When overwriting an existing route there is problem that the format gets destroyed. The tour can be loaded in the app itself (obviously the wrong data is ignored), but not anymore in the web application. Example [Mjölnir Tour Eifel Lux Schönecken wrong.kurviger](https://forum.kurviger.com/uploads/short-url/2Yg7jdtxO6CClazIoUHZ98s4f73.kurviger) (68.6 KB) The wrong data is here [grafik] The correct format is not written into the file, somehow previous code remains in the file and leads to the destruction of the format. The workaround is to delete the existing route before ex…
