Follow Modus
Hello everyone.
Whenever I start the Kurviger app on the iPhone in Follow mode, the message appears:
Let’s go, 110 km to go.
But there is no route stored.
Hello dl1bax,
welcome to Kurviger forum. Can it be that the last route you planned still persists? What happens if you tap on the 3 dot button in the upper left section? If there is the option at the end ‘delete route’ just do it and the message should vanish.
It happens on my IPhone as well.
DE: “Los geht´s”. Dem Strassenverlauf für 111 km folgen"
When I switch the language it is even more strange.
EN: “Let´s go. Dem Strassenverlauf für 111 km folgen”
FR: “Allons y. Dem Strassenverlauf für 111 km folgen”.
I have tried to load different routes before, I deleted local data, I uninstalled an re-installed - always the same.
Thanks Toffel for verifying this :muscle:, I’ll take it to the team.
I can verify this, we will have a look at that, thanks :+1:
When starting Follow-Mode under Navigation I am instructed to follow the route for 111 kilometres. Well, there is no route. :slight_smile: Is this expected behaviour? I am using the IOS app.
Best regards, Markus
I think we can merge.
Thanks for letting us know, we have this issue on our todo list already and will provide a fix for this in the future.
Same here.
