Du könntest auf der anderen Seite des Baches einen Punkt setzen (Erweitere Route nach) und beide Punkte mit einer Fluglinie verbinden. Etwa so
Laut Google Maps kannst du da lang fahren.
Ich vermute, es ist ein Fehler in OSM.
Koordinaten: Maps: 38°49’50.5"N 23°13’13.0"E
Kurviger: 38.830701991581776, 23.220286329909584
Schicke bitte mal Link zu dem Weg.
Hello @Shoko_Ranni,
if you ever encounter a problem like this (presumably an error in the OSM map data) you can help yourself by using the beeline function as a workaround until the error is corrected.
This bridge was set to “construction” about one year ago and the change record contains this article as reference - but it is from 2019! There was a revert from vandalism, but since this revert it contains the “construction” tag. I guess the revert was not complete.
I tend to remove the tag "construction. What do you think? I removed it with 184035091.
@Shoko_Ranni: when you drive this road and it is really blocked, please let us know!
