K3 won't start on Carpe Iter
Thanks for the update :slight_smile:.
Just recived my CI yesterday and unfortunately my Kurviger app is not working either. Same problem as the other guys discribed.
I already installed webviewer, chrome and firefox … but nothing has changed. Is there already a solution available?
Thanks, Daniel
Unfortunately not. Maybe you also can create a ticket on the thork racing website to give this topic a bit higher priority.
Bad news :roll_eyes: … okay. I will open a ticket and let you know as soon as I recive an answer.
Seems we will have to wait for a longer period, this answer I got from Carpe Iter today:
Support replied
2023-03-30 18:24:12
The Android updates take quite some time to develop and we already started with android 11. At the moment we don’t have an ETA for it.
Peter
You replied
2023-03-29 21:06:55
Thank you.
May I ask, why not Android 12 or better 13. 11 is quite outdated already.
Any plans when it’s going to be released?
I just posted this in a different thread, but figured it might solve the Carpe Iter start problem as well:
Thank you, Robin,
But playstore shows a message that the product is not compatible with the device.
Annoying!
Ok, thanks for checking, I did some more digging, so it seems Carpe Iter has not made their Webview Updatable.
I did some research, here are links with more info, if you are interested, it’s very techy but I figured I will add this for reference.
https://chromium.googlesource.com/chromium/src/+/HEAD/android_webview/docs/aosp-system-integration.md#Making-your-WebView-updatable
https://groups.google.com/a/chromium.org/g/android-webview-dev/c/apA8HXJpGr0/m/gqAaDdCyAQAJ
I do have the same issue with a Carpe Iter Pad running Android 9.
No Add blocker, Chrome is up to date and all other apps running without any issues.
The old Kurviger Pro app also worked fine.
This is a known issue for Carpe Iter unfortunately, I moved your thread to the correct topci.
I’m having the same issue on an Samsung Active Tab 2 that I just purchased, it is running Android 9 and the apps are all up to date. I think it is very similar to the Carpe Iter tablet. I get the same error on other websites, like trying to access taskernet.
Samsung usually has an updatable Webview, I would be surprised if it would be the same issue, I would recommend to first try other options, for example:
https://docs.kurviger.de/web/faq/browser_incompatible
https://forum.kurviger.com/t/uncaught-syntax-error-unexpected-token/10837/6
Very interesting, thank you. I’m learning something new every day.
I tried the update and it started working.
Merci beaucoup de l’info sur Android 5 minimum pour utiliser kurviger 3, désolé mais avec deux smartphones l’apk ne tourne pas :
-Likebook Mars androïd 8.1.0 message kurviger 3.0.7 « uncaught syntax error : unexpected token ‘.’» erreur de syntaxe non interceptée : token ‘.’ inattendu
-Nomu Android 6.0.1 même message mais curvy 2.2.28 fonctionne correctement. Toute les applications sont a jour, chrome aussi.
Je souhaite utiliser mon ancien smartphone Nomu (android 6.0.1) sur ma honda goldwing car les jours de pluie ne lui posent aucun problème, il est étanche. Merci de réparer kurviger 3.0.7 pour android 6 et suivant s’il vous plait.
(Aucun problème de fonctionnement avec mes machines récentes Wiko et huawei sous Android 8.0.)
Just to clarify Kurviger v3 should work fine on Android 6 devices, if you can update the Webview. Most device manufacturers make their Webview implementation updatable. You don’t need the latest webview, 2-3 years old version should still work (latest version is always recommended). The official documentation (linked above) recommend to make the Webview updatable.
I don’t know why some manufacturers don’t do this and there is unfortunately no way to support webviews that are that old. So for now there is nothing we can do on our end, I am sorry. Webview is a hard requirement for Kurviger v3.
You can try the tips I have posted above, maybe they work on your device.
Merci, j’ai fait cela sur mon nomu et cela a fonctionné sauf que en mode test de navigation au bout de quelques kilomètres il n’y a plus de carte ! Juste le trait bleu de la route avec les virages.
Sur ma likebook mars j’ai installé Android webview mais ça n’a rien changé.
Merci encore.
I am happy that this helped :+1:. Are you connected to the internet? If there is no map loaded, this can be related to an internet issue. If this issues continues, could you please create a separate topic for this, as this has nothing to do with Carpe Iter or the Webview :slight_smile:
Ok merci beaucoup
Good news for CI-Pad users. Carpe iter will publish a hot fix for Kurviger as well as a rom update later this year. Got this reply to my ticket:
Hello Peter,
We are aware of the problem - there is a completely new Kurviger app released recently. We will be releasing a hot-fix guide in couple days (already tested procedure) and ROM update later this year to deal with that (and a few other) issues. We just need a few more days to also finish Controller app update so that our controllers work with the new Kurviger app (it is really a completely new app, not a simple update).
Please feel free to post a copy of this message on the Kurviger forum.
We are sorry for the trouble.
Best regards,
Carpe
