How to customize map styles in Android Auto?
I can change the map styles in the Android app. Here I like to use the high-contrast OTM map style. Unfortunately, this adjustment is not transferred to the Android Auto display. Only the default map style is shown there.
Am I missing an option here or is this really not possible? If the latter, is anything planned for this?
With OTM, for example, fields and forest paths that branch off from the regular road are easy to see, making it easy to spot where you can stop for a short break.
Best regards, Uwe :victory_hand:t2:
Hi Uwe,
the maps can only be selected for planning on the web and in the app. As soon as you start navigation (in the app and AA), there is only one map that cannot be changed. Since there is no planning mode as such in AA, you cannot select a map there either.
Nothing known at the moment.
True… I just started the navigation in the simulation and then the map style in the app also switches to standard. I don’t use the app directly, so I hadn’t noticed that.
Then that would be a feature request :wink: I’ve already mentioned the reason why. Map details are simply missing during navigation.
Thanks and best regards :victory_hand:t2:
Uwe
Where is the best place to submit a feature request for the map style? Personally, I think a higher-contrast map for navigation makes a lot of sense, and I’d be curious who else feels the same :wink: that’s the only reason I still mostly use a different app for navigation :man_shrugging:t3:
I would point out here that more details also require significantly more processing power. This can cause problems for older phones. Additionally, map data is downloaded before the trip starts, if it hasn’t been already. That can be pretty terrible with a poor network. Otherwise, it definitely looks cool, but does it really help?
When I’m riding alone, I can brake “sportily” if, for example, I see a forest path as a spot for a short break in the woods. When I’m riding with people, that’s not a good idea. But if, for instance, the forest path is clearly visible on the map, I can reduce my speed accordingly in advance. I found that very helpful on my Garmin navigation devices and currently also on the OSMAnd+ app with Android Auto. There are also other reasons why more clearly visible dirt roads are sometimes helpful :grin:
I misunderstood you earlier; the forest paths = “nature break” for ladies too, are really hard to see! In that case, the goal would be to optimize the existing map.
On AA, depending on the resolution, this might look even worse
On Android Auto, forests and dirt roads are completely invisible at normal speeds.
Hi @Uwe,
We always read along :wink:
Thanks for your feedback in any case. It’s just not a trivial topic, because everyone misses different details here or finds other info to be too much. Therefore, it’s a balancing act and simply needs to be well thought out. :thinking:
Actually, nothing needs to be added at first. As seen in the screenshot above, the forest paths are already displayed. The contrast just needs to be better and they should still be displayed at normal speed zoom levels.
Best regards, Uwe
