# Keine Navigation bei deaktiviertem Display
**URL:** <https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401>\
**Category:** App\
**Tags:** beta\
**Created:** [May 6, 2023, 7:21pm UTC](https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401 "2023-05-06T19:21:53Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![Kubi](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/k/f04885/32.png) [@Kubi](https://forum.kurviger.com/u/Kubi)\
**Post date:** [May 6, 2023, 7:21pm UTC](https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401/1 "2023-05-06T19:21:53Z")
</div>
bei ausgeschaltetem Bildschirm erfolgt keine Sprachausgabe mehr. Während der Simulation allerdings schon.
Beste Grüße
Sebastian Kubitza
Device: samsung - SM-G973F - Android: 12 - WebView: 112.0.5615.135
App-Version: 3.0.8 - 1009
Screen: 412 x 869 px - 2.625dppx
**Author:** ![linux-user](https://forum.kurviger.com/user_avatar/forum.kurviger.com/linux-user/32/56_2.png) [@linux-user](https://forum.kurviger.com/u/linux-user)\
**Post date:** [May 7, 2023, 6:54am UTC](https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401/2 "2023-05-07T06:54:46Z")
</div>
Schau mal hier:
> [@Beta version voice directions stop when Android screen is off](https://forum.kurviger.com/t/beta-version-voice-directions-stop-when-android-screen-is-off/10665):
> When using the beta app the voice directions stop whenever the screen is off. The previous version was perfectly happy to continue to give voice directions even when the screen was off. The music player that I use continues to work with the screen off. The Kurviger audio, however, stops.
**Post date:** [May 7, 2023, 12:02pm UTC](https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401/3 "2023-05-07T12:02:41Z")
</div>
Zusätzlich noch der Hinweis auf unsere Doku: [Ich höre keine Sprachausgabe / Abbiege-Anweisungen [Kurviger Knowledgebase]](https://docs.kurviger.de/de/app/faq/navigate_no_voice_prompt)
**Author:** ![helste](https://forum.kurviger.com/user_avatar/forum.kurviger.com/helste/32/5988_2.png) [@helste](https://forum.kurviger.com/u/helste)\
**Post date:** [May 8, 2023, 7:54am UTC](https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401/4 "2023-05-08T07:54:27Z")
</div>
Auf meinem Smartphone (Xiaomi Note Red 5) gibt es nur die Möglichkeit Standortzugriff ein oder aus. Eine Option “Allow all the time” gibt es da nicht. Früher ging bei mir die Sprachnavigation, wenn das Display aus war, jetzt nicht mehr. Muss mal mit der alten Kurviger app probieren, ob es damit noch geht, oder ob es mit einem MIUI Update zusammenhängt. Wäre blöd, wenn das nicht mehr ginge. Dann müsste ich das Display an lassen (Akkuverbrauch hoch) oder mir ein neues Smartphone zulegen.
**Post date:** [May 8, 2023, 8:02am UTC](https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401/5 "2023-05-08T08:02:25Z")
</div>
> [@helste](#):
Bei älteren Android Versionen gab es das noch nicht, da konnte man aber auch den Standortzugriff auf “Immer” oder so ähnlich setzen.
Es gibt ja auch noch das Thema Batterieoptimierung, diese musst due für die Kurviger App deaktivieren. Details dazu findest du auch in der Doku bzw. der Link auf [https://dontkillmyapp.com/](https://dontkillmyapp.com/)
**Post date:** [May 8, 2023, 8:18am UTC](https://forum.kurviger.com/t/keine-navigation-bei-deaktiviertem-display/11401/6 "2023-05-08T08:18:30Z")
</div>
Danke für den Tipp mit der Batterieoptimierung. Die war für die neue App noch nicht richtig gesetzt. Eventuell hilft das ja schon. Werde es nachher gleich mal ausprobieren.
