# No route documentation when deviating from planned route
**URL:** <https://forum.kurviger.com/t/keine-routen-dokumentation-wenn-von-geplanter-route-abgewichen/27472>\
**Category:** Navigation\
**Tags:** navigation\
**Created:** [September 11, 2026, 7:42am UTC](https://forum.kurviger.com/t/keine-routen-dokumentation-wenn-von-geplanter-route-abgewichen/27472 "2026-09-11T07:42:42Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Flinder](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/f/74df32/32.png) [@Flinder](https://forum.kurviger.com/u/Flinder)\
**Post date:** [September 11, 2026, 7:42am UTC](https://forum.kurviger.com/t/keine-routen-dokumentation-wenn-von-geplanter-route-abgewichen/27472/1 "2026-09-11T07:42:42Z")
</div>
Problem: I’m riding a planned route – towards the end, I feel like doing a little extra loop and therefore deviate from the route. Kurviger then records my actually ridden route (dashed red line), but only logs the ‘deviated’ loop as my riding performance. Meaning, out of 140 km, maybe only 20 km are saved as a route. The rest is simply lost.
What am I doing wrong?
Thanks! Vanessa
**Author:** ![Kira](https://forum.kurviger.com/user_avatar/forum.kurviger.com/kira/32/23135_2.png) [@Kira](https://forum.kurviger.com/u/Kira)\
**Post date:** [September 11, 2026, 7:46am UTC](https://forum.kurviger.com/t/keine-routen-dokumentation-wenn-von-geplanter-route-abgewichen/27472/2 "2026-09-11T07:46:41Z")
</div>
Hi @Flinder,
When navigation is active, Kurviger records your actual ridden route. The route recording is visible during the trip as a solid red line. It sounds more like you might have lost GPS signal in between? Check your device’s settings under “Apps” to see if Kurviger has full permission for “Location”.
**[You can find everything about route recording here.](https://docs.kurviger.com/de/app/route_recording)** 💡
**Post date:** [September 13, 2026, 12:31pm UTC](https://forum.kurviger.com/t/keine-routen-dokumentation-wenn-von-geplanter-route-abgewichen/27472/3 "2026-09-13T12:31:28Z")
</div>
Thanks @Kira, it records the tour (red line), but then doesn’t save the entire tour, only the remaining part that deviated from the “planned”/loaded tour. When I finish the tour, the actually ridden tour is visible as a red/purple dashed line, except for the deviating rest, which is shown with a blue line. And that blue rest is then the only thing that gets saved.
And yes, I have set full location permissions and the tour recording info isn’t helpful here.
Best, Vanessa
**Author:** ![linux-user](https://forum.kurviger.com/user_avatar/forum.kurviger.com/linux-user/32/56_2.png) [@linux-user](https://forum.kurviger.com/u/linux-user)\
**Post date:** [September 13, 2026, 2:01pm UTC](https://forum.kurviger.com/t/keine-routen-dokumentation-wenn-von-geplanter-route-abgewichen/27472/4 "2026-09-13T14:01:19Z")
</div>
> [@Flinder](#):
> When I finish the tour, the actually ridden tour can be seen as a red/purple dashed line, except for the deviating rest, which is shown with a blue line. And that blue rest is then the only thing that gets saved
When you “finish the tour” and then confirm with “save”, the entire recorded GPX track should be in the “Recorded Tours” folder.
Which part of the tour is saved there for you?
1. The planned part?
2. The unplanned part?
3. Or the entire tour (planned and unplanned)?
**Post date:** [September 15, 2026, 2:23pm UTC](https://forum.kurviger.com/t/keine-routen-dokumentation-wenn-von-geplanter-route-abgewichen/27472/5 "2026-09-15T14:23:39Z")
</div>
> [@Flinder](#):
> the actually ridden tour can be seen as a red/purple dashed line, except for the deviating rest, which is shown with a blue line. And that blue rest is then the only thing that gets saved.
Could you please send a screenshot of it so we can better understand what’s going on?
Otherwise, I would agree with @linux-user: What exactly do you find in your “Recorded Tours” folder?
