Hi again,
due to my vacation (motorcycle trip) in a few days I had some doubts if I should update kurviger such a short time before, but due to several very interesting topics in the change list and positive experiences in the past (I never had problems with kurviger updates) I decided to do so - that was a good descision!
I only see improvements - good job done (by kurviger developers)!
Nevertheless I want to propose a small change in the handling of the export name proposal:
If I import a route XYZ, in next export the name proposal is XYZ, that’s fine. If I change the name during export, i.e. XYZ_v00, this name change should be remembered and be the proposal for the next export ( as long as I do not import an other route).
This is the usual behaviour of nearly each program I know: Opening a file and selecting “Save as…” later proposes the name of the opened file. If I change the name, save and do a further “Save as …” later, the changed name will be proposed.
Thanks a lot with best regards
Markus
