# Kurviger 2.0.11 (Beta)
**URL:** <https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421>\
**Category:** News and Updates about Kurviger\
**Created:** [April 22, 2021, 8:27am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421 "2021-04-22T08:27:27Z")\
**Posts on this page:** 20\
**Page:** 6
<div class="post-metadata">
**Author:** ![WalterG](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/w/f0a364/32.png) [@WalterG](https://forum.kurviger.com/u/WalterG)\
**Post date:** [April 25, 2021, 5:39pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/116 "2021-04-25T17:39:28Z")
</div>
> [@Hannes](#):
> Wo werden diese aufgezeichneten Routen gespeichert?
Bitte schau mal in der Doku:
DE: [Kurviger PRO: Navigation, Simulation, GPS-Aufzeichnung, Displaysperre, Rerouting, Mehr, Offline-Benutzung [Kurviger Knowledgebase]](https://docs.kurviger.de/de/app/manual/pro#gps-aufzeichnungs-modus_und_zugehoerige_aktionen)
EN: [Kurviger PRO: Navigation, Simulation, GPS Recording, Screen Lock, Rerouting, More, Offline use [Kurviger Knowledgebase]](https://docs.kurviger.de/start?id=app/manual/pro#gps_logging_mode_and_related_actions)
Hilft das weiter? Bitte um kurze Rückmeldung. Danke im Voraus.
**Post date:** [April 25, 2021, 5:45pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/117 "2021-04-25T17:45:07Z")
</div>
> [@Hannes](#):
> I mean the recorded tracks, which are permanently shown. Where are these recorded tracks stored?
Do you mean the GPS logging’s recorded track?
It is stored in app’s private storage and you can already export it as GPX.
Currently it cannot be re-imported in the app.
This is an interesting idea: import saved tracks in GPS logging.
I can see how it is possible to implement.
**Post date:** [April 25, 2021, 5:51pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/118 "2021-04-25T17:51:56Z")
</div>
> [@devemux86](#):
Really not be re-imported? Not at GPS logging, but should be possible to import the gpx file at
Menu-Button \> Routing \> Import
as Overlay?
Or am I wrong with this?
**Author:** ![Hannes](https://forum.kurviger.com/user_avatar/forum.kurviger.com/hannes/32/2746_2.png) [@Hannes](https://forum.kurviger.com/u/Hannes)\
**Post date:** [April 25, 2021, 5:53pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/119 "2021-04-25T17:53:24Z")
</div>
> [@WalterG](#):
Danke, das hat geholfen, ich habe den GPS-Track gespeichert und als Overlay in Kurviger 2 importiert.
**Author:** ![ToTo\_GSA\_Rider](https://forum.kurviger.com/user_avatar/forum.kurviger.com/toto_gsa_rider/32/28483_2.png) [@ToTo\_GSA\_Rider](https://forum.kurviger.com/u/ToTo_GSA_Rider)\
**Post date:** [April 25, 2021, 5:59pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/120 "2021-04-25T17:59:32Z")
</div>
Okay, ich bin davon ausgegangen wenn ich die Navigation auf 3D nutze bzw. im Menü darauf einstelle, dass der Folgemodus auch automatisch in 3D ausgeführt wird. Danke aber trotzdem für die Info.
Okay, I assumed when I use the navigation on 3D or set it in the menu that the follow mode is also automatically executed in 3D. But thanks for the info anyway.
**Post date:** [April 25, 2021, 6:01pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/121 "2021-04-25T18:01:40Z")
</div>
> [@devemux86](#):
> You mean the GPS logging’s recorded track.
This would be nice, I like this feature in Calimoto, where I can see, where I have already been. This gives me nice memories.
I would like to have the opportunity to save routes,which I have done and to copy them to a new mobile phone.
**Post date:** [April 25, 2021, 6:02pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/122 "2021-04-25T18:02:25Z")
</div>
> [@WalterG](#):
> as Overlay?
I thought the question is to re-import a GPX file as recorded track in GPS logging?
Of course you can import GPX files as overlays!
Please see the manual:
[https://docs.kurviger.de/app/manual/route#import\_load\_open](https://docs.kurviger.de/app/manual/route#import_load_open)
**Post date:** [April 25, 2021, 6:12pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/123 "2021-04-25T18:12:31Z")
</div>
> [@ToTo\_GSA\_Rider](#):
Follow mode has its own options when tap the compass.
You can enable the “Settings | Navigation | Follow after arrival”.
After arrival at destination, follow continues with same 2D / 3D.
**Post date:** [April 25, 2021, 6:32pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/124 "2021-04-25T18:32:06Z")
</div>
Also bei mir ist die Navigation nicht im 3D geblieben. Auch als ich dann die Route gelöscht habe und den Folgemodus gestartet habe ist es nicht auf 3D gesprungen. In der Version 1 ging das auch so, deshalb bin ich ja verwundert. Vielleicht schaut ihr da nochmal drüber.
Aber der Tipp mit dem Kompass war auch schon super
So for me, the navigation did not stay in 3D. Even when I deleted the route and started the follow mode it did not jump to 3D. In version 1 it also worked like that, that’s why I’m surprised. Maybe you look at it again.
But the tip with the compass was also already great
**Post date:** [April 25, 2021, 6:43pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/125 "2021-04-25T18:43:45Z")
</div>
Navigation stays in the mode you set it to work.
_Follow location after navigation_ uses navigation 2D / 3D mode,
if you have enabled “Settings | Navigation | Follow after arrival”.
If you delete the route, you stop navigation.
If you start the follow via long press the location button, this is not navigation.
Then you need to tap compass to select the map orientation.
Please explain exactly the steps and options, so we can understand what happens.
**Post date:** [April 25, 2021, 6:49pm UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/126 "2021-04-25T18:49:22Z")
</div>
Ja, hier ein Screenshot
[Screenshot\_20210425-204820\_Kurviger|225x500](https://forum.kurviger.com/uploads/short-url/yNyIGbVnDMKWtDiF58RXfOS6Njj.jpeg)
**Author:** ![Tom](https://forum.kurviger.com/user_avatar/forum.kurviger.com/tom/32/168_2.png) [@Tom](https://forum.kurviger.com/u/Tom)\
**Post date:** [April 26, 2021, 4:53am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/127 "2021-04-26T04:53:56Z")
</div>
> [@FraBe](#):
> Ging ganz einfach und schnell (kurviger FREE installieren, für beta anmelden, 10min gewartet, Update). Alles gut. Einstellungen aus pro 1 exportiert und in 2 importiert. Dazu noch ein wenig angepasst.
Hört sich gut an, bei mir funktioniert das einfach nicht. Habe Kurviger Free jetzt schon mehrfach neu installiert, Werbung akzeptiert und auch den Link für das Beta Programm angeklickt, aber die Version 2 kommt einfach nicht.
**Post date:** [April 26, 2021, 4:59am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/128 "2021-04-26T04:59:09Z")
</div>
- Did you install [Kurviger 1 Free](https://play.google.com/store/apps/details?id=gr.talent.kurviger)?
- And register in the correct [new Beta program](https://play.google.com/apps/testing/gr.talent.kurviger)?
**Post date:** [April 26, 2021, 5:06am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/129 "2021-04-26T05:06:01Z")
</div>
> [@devemux86](#):
I installed Kurviger 1 Free from the Store because if I click on the Kurviger 1 Free link I get the information that the google account which I use in the web is not the same that I use on my device. Maybe this is why it is not working?
**Post date:** [April 26, 2021, 5:08am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/130 "2021-04-26T05:08:21Z")
</div>
Google is responsible and handles Google Play updates.
If you have done everything correctly, you can only wait for the update.
> [@Tom](#):
You must register in the Beta program with your device Google account.
How else will Google Play know that an account is registered in the program?
**Post date:** [April 26, 2021, 5:13am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/131 "2021-04-26T05:13:34Z")
</div>
> [@devemux86](#):
ok seems to be the problem. When I now use the link for install I am asked to select the device of 4. Is this version then only running on this one device? Do I have then to use this link on all other devices too to use the Beta or is this then done automatically?
**Post date:** [April 26, 2021, 5:14am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/132 "2021-04-26T05:14:54Z")
</div>
Please just follow the instructions:
- Install [Kurviger 1 Free](https://play.google.com/store/apps/details?id=gr.talent.kurviger) in your device
- Register in the [new Beta program](https://play.google.com/apps/testing/gr.talent.kurviger) using the device account
Google links the apps and purchases with the accounts.
You can see [Google Play Help](https://support.google.com/googleplay/answer/113410) for more details.
**Post date:** [April 26, 2021, 7:01am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/133 "2021-04-26T07:01:37Z")
</div>
Split this topic on April 26, 2021, 7:01am UTC
4 posts were merged into an existing topic: [App: Navigation UI design](https://forum.kurviger.com/t/app-navigation-ui-design/5369/16)
**Author:** ![Maxx18](https://forum.kurviger.com/user_avatar/forum.kurviger.com/maxx18/32/7016_2.png) [@Maxx18](https://forum.kurviger.com/u/Maxx18)\
**Post date:** [April 26, 2021, 6:03am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/134 "2021-04-26T06:03:21Z")
</div>
Vielleicht meint er die tausende km-langen GPS-Aufzeichnungen, die auf dem Display angezeigt werden können.
Perhaps he means the thousands of kilometers of GPS records that can be shown on the display.
**Post date:** [April 26, 2021, 7:09am UTC](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421/135 "2021-04-26T07:09:42Z")
</div>
Split this topic on April 26, 2021, 7:09am UTC
A post was split to a new topic: [You are not permitted to view the requested resource](https://forum.kurviger.com/t/you-are-not-permitted-to-view-the-requested-resource/5470)
[Previous page](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421.md?page=5)
[Next page](https://forum.kurviger.com/t/kurviger-2-0-11-beta/5421.md?page=7)
