I am quite new to Kurviger, coming from Calimoto.
At this intersection I wanted to go straight, so from bottom to top, see photo (I think this has happened in similar situations before though…), coming from bottom I get the voice prompt “turn right”. Then you turn right and then the prompt comes “turn left” - too sure, turn around… . Sure, you can also look at the display, but here the offset is so small that I’ve never noticed it as an offset.
That wasn’t a problem with Calimoto or half a dozen other navigation apps. Yes, some say: “turn right and then immediately left”. You can live with that too.
I’ve had that happen quite a few times too. Turn instructions for minimal direction changes. Glancing at the display usually helps, but I’ve driven the wrong way too.
Kurviger does the exact same thing. “turn right onto the L207a, then turn left onto Volzen”. You can skip the word “immediately”, because if it’s not right after, the “turn left” wouldn’t be announced either.
Is it different for you? Here is the link: Kurviger – Motorcycle Route Planner & Navigation
Could be because of the other map, perhaps?
With Kurviger, it NEVER told me to go straight here, but always right and then left, although the “and then left” kind of got lost anyway and a bit further on it wanted to turn around.
This spot is just an example; I experienced this at several intersections in the first 300 km. I think the programmers could build in some kind of tolerance there—anything less than 5m for right/left or left/right counts as going straight.
It would be much easier if you shared your route so we can look at it in the simulation. Linux-user explained further up how you can share a route here.
None of us know what preferences are set for the tour, maybe even a “weird” shaping point. ![]()
So let’s stop speculating and please share the route. Please also mention the next waypoint so the location can be found more quickly. ![]()
BTW
Programmers only really get active when you can test or reproduce it in a real-world scenario.
Here you go: Kurviger – Motorcycle Route Planner & Navigation
I had included a coordinate in the photo in my post. But never mind.
Thanks
Hi @roy,
I just simulated it with the route you shared. Kurviger says “turn right, then turn left” before you’ve reached the intersection and turned right.
Surely it’s different for you? Please try running the simulation again as a cross-check.
I generally find the voice prompts okay. In this case, I would rather say the intersection in OSM is “in need of improvement”. Only two nodes need to be nudged.
I also have a few spots in my area where “straight ahead” would mean driving straight into a house wall. I find Kurviger’s right/left prompts more helpful than a “Follow the road”. Imho.
That is survey data, after all. And the small offset (I estimate under 1m) is real.
Right, that’s what happens in the simulation. But when I drove it in real life, it didn’t happen several times. No idea why. I just think that for such relatively small offsets, there should be a tolerance threshold set—and presumably there already is one, in which case it needs to be at least 5 m.
The voice prompt in real life was different from the one in the simulation.
Even so, an offset of less than 5m (i.e., less than one lane width) can still be described as going straight ahead, especially on a motorcycle, where you typically ride through minor offsets without steering corrections, much like certain S-chicanes at town entrances.
exactly why I had also written:
and asked to share the route YOU drove. I assume that the route is saved in your cloud and that’s why I also wrote:
And as Toffel generally wrote about the matter:
It is something that should be represented better in OSM. Kurviger doesn’t necessarily have the ability to initiate an improvement in navigation at such places.
Especially since the navigation map also clearly shows, first turn right, then turn left. That is already a visual difference to your satellite screenshot. ![]()
Feel free to report the matter in the OSM forum. There are enough mappers there who really know their stuff to sort that out. And that should only be done by people who can also look at the situation on site.
But isn’t it strange that some navigation systems generate better instructions using these exact OSM definitions?
Wait a day and check again.
You think the roads in OpenStreetMap are surveyed? No, that’s not the case. Aerial imagery or GPS tracks are used. Draw a line, set attributes, the road is there.
If you look at the satellite map, what was drawn in a simplified way is a huge difference from reality.
I straightened out the offset because it can hardly be the intention of a road builder for traffic participants to zig-zag.
You have to take a close look at a built intersection. Gentle radii from the faster road so that no one slows down traffic significantly. Fairly tight angle onto the fast road. Drive off, after 10 m the wheels are straight and full throttle. The islands are designed so that at least two vehicles can drive up to the stop line. Hats off.
The radii and the islands deceive about the course of the road. If I draw a straight line, it fits, it goes straight without offset. The driver just needs to be able to avoid the islands.
It gets even more elaborate in OSM, off-ramp, on-ramp, connecting ways around traffic islands. It’s a trade-off between effort and accuracy. Thanks to the mapper who mapped it in the first place. If you don’t like it, improve it. OSM is very easy.
As a local, if you were to generally apply a 5m tolerance, at Xinedom wouldn’t you drive right towards the station and not into the tunnel?
