Last sunday on a Black Forest Route I noticed, that the information at the top of the navigation screen disappeeras and the fields became empty (“–”).(pic 1).
This took at least 8 minutes.
I cleared the route and imported it again - no change.
I closed the app, started it again and only then the information came back.
Did you try to double press on the navigation button? Did you use the “use orientation” option under settings? Could it be, that you were cruising in the wrong direction (sounds stupid, but it happened to me before as well :D). Any other ideas @devemux86?
((BTW: I am just using the New Forum with my smartphone, whereas before I posted via pc - there are some minor differences like using “quotes” of posts, which seems to do not work, or the drop down menue of emoticons, which does not work well.))
I would recommend to double hit the navigation button in these cases. Otherwise it would be helpful to have a GPX track and the planned route to see if the same thing happens again if we replay the GPX track, this could help to narrow down the problem. But in general it is hard to tell with one-off situations without knowing what exactly happened. The orientation support is still in Beta because there could be some edge cases that break the navigation.
It worked for me. I quote by marking the text in a different message and once it’s marked there is a quote popup. Emoticons seem to work for me as well, could you explain what happened?
THIS did not help - similar to clear the route and re-import it.
Since after restarting the app it worked again (without moving!) this seemed an internal issue of the app.
A bit difficult to understand from only the image, seems user location is not projected correctly on the route there.
In such cases would help greatly to have besides screenshots, also the route (gpx or kurviger), the position of the event and the enabled navigation options.
Then I could replay the event in my navigation simulator and debug the core variables to see what happens.
I have the same problems. No infos at the top after rerouting but GPS is on and the vehicle marker is correct.
Where do I find the “Orientation support” in the navigation settings?
After leaving the road for about 100 m to have a short break, I wanted to see how far destination will be - but was disappointed because header information was gone (pic 1).
Then, after I got back near the road, information apperead again (pic 2).
Any explanation - for example because it was no legal road but only a lane between the fields?
Any work around for those situations?
The first examples above seem involved in corner cases with bearing, I’m looking to improve the algorithm variables there.
The last example seems normal? If get away from the route (e.g. 100m), this is considered “off route” situation and cannot navigate or provide instructions (1st image). When get close to route again the navigation resumes (2nd image).
I had a similar situation on my tour. I tried to click several buttons, I restarted kurviger and I even rebooted my phone but it didn’t solve the problem. At some point later it worked again without doing anything. I also don’t have any screenshots and no gpx, in fact this wouldnt help as I couldnt tell exactly where it happened. I just remember that I was driving on the regular route, didn’t leave or did a u-turn or whatsoever.
I know this won’t help much for your investigations, but it seems to occur not so seldomly.
