# New route planning UI | Neue Routenplanungs-UI
**URL:** <https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879>\
**Category:** News and Updates about Kurviger\
**Tags:** web-version\
**Created:** [November 5, 2026, 12:12pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879 "2026-11-05T12:12:39Z")\
**Posts on this page:** 20\
**Page:** 2
<div class="post-metadata">
**Author:** ![Thoka](https://forum.kurviger.com/user_avatar/forum.kurviger.com/thoka/32/13810_2.png) [@Thoka](https://forum.kurviger.com/u/Thoka)\
**Post date:** [November 6, 2026, 4:28pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/21 "2026-11-06T16:28:56Z")
</div>
> [@Toffel](#):
> Meinen Start setze ich in der Regel zuerst und auch per Favorit,
In most cases, I set the destination first and use the implicit function where the starting point is populated with the current location.
And often I reverse the route and then delete either the start or destination to replace a value.
To do this, I now first have to switch to the waypoint list.
Now, unfortunately, the waypoint list closes automatically if only one value remains ☹ and thus both values are „lost“.
 ![image](https://forum.kurviger.com/uploads/default/original/3X/8/8/88d506a92a9b50d2adbe12d63072181d0991a18c.png)
That used to be implemented better because I could specifically populate the start/destination here.
 ![image](https://forum.kurviger.com/uploads/default/original/3X/8/6/865b32901a672d5e267b7f0163ce9416e53ab0b0.png)
**Author:** ![Ilias](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/i/3bc359/32.png) [@Ilias](https://forum.kurviger.com/u/Ilias)\
**Post date:** [November 6, 2026, 5:55pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/22 "2026-11-06T17:55:51Z")
</div>
This type of input with the ability to adjust the curveness directly is quite effective. It just needs a (+) next to the curveness and at the very bottom to enter more waypoints/destinations.
If avoidance options were also integrated into the curveness settings, the app would be one of a kind.
**Author:** ![Maxx18](https://forum.kurviger.com/user_avatar/forum.kurviger.com/maxx18/32/7016_2.png) [@Maxx18](https://forum.kurviger.com/u/Maxx18)\
**Post date:** [November 6, 2026, 7:21pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/23 "2026-11-06T19:21:26Z")
</div>
> [@Ilias](#):
> If you then also integrated avoidances into the curvy routes, the app would be unique.
If I remember the previous discussions about this, a single avoidance would be enough: highways
**Author:** ![Andy\_Kreft](https://forum.kurviger.com/user_avatar/forum.kurviger.com/andy_kreft/32/32321_2.png) [@Andy\_Kreft](https://forum.kurviger.com/u/Andy_Kreft)\
**Post date:** [November 6, 2026, 8:05pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/24 "2026-11-06T20:05:45Z")
</div>
Unfortunately I’ve been having issues with my NordkappTour since the update
I can open the route, but any changes result in a calculation timeout
**Author:** ![dingesd](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/d/a183cd/32.png) [@dingesd](https://forum.kurviger.com/u/dingesd)\
**Post date:** [November 6, 2026, 8:06pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/25 "2026-11-06T20:06:02Z")
</div>
Can I please get the old version back. Sorry, but the new one is so confusing and cluttered that it’s no longer fun. Previously it was one click, and the blank line was immediately where you wanted it; today it’s placed at the bottom as a destination, you have to awkwardly move it, and then also hunt for the collapsed shopping etc. Sorry, it’s definitely a case of “improvements” that made things worse.
**Author:** ![GuG](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/g/76d3ee/32.png) [@GuG](https://forum.kurviger.com/u/GuG)\
**Post date:** [November 6, 2026, 9:20pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/26 "2026-11-06T21:20:10Z")
</div>
Although I like the new interface, unfortunately I can no longer plan a route as I used to. I use Kurviger in the web version on a 12-inch Lenovo tablet. What works in the app—setting the start, destination, and via points by long-pressing on the map and then selecting—is not possible in the web version. Input seems to only be possible via the search function. But I never plan that way. I simply place the start, destination, intermediate destinations, and shaping points on the map, no matter what the point is called (I don’t care). How exactly do you do that in the new design?
edit: I just noticed that on the Windows computer on the web, it still works like before (right-click). Unfortunately, on the tablet, that doesn’t seem to work without a mouse.
**Post date:** [November 6, 2026, 9:41pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/27 "2026-11-06T21:41:08Z")
</div>
I want to decide for myself which exceptions should be taken into account in the curves.
**Author:** ![schippy](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/s/e495f1/32.png) [@schippy](https://forum.kurviger.com/u/schippy)\
**Post date:** [November 6, 2026, 10:53pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/28 "2026-11-06T22:53:36Z")
</div>
The new interface looks good.
Normally, I plan by setting the start and destination first, then adding waypoints in between, and finally refining it with shaping points.
Now I am missing the option to insert a new waypoint between the start and destination.
Currently, I have to shift the points with every intermediate destination.
It would be great if there were a “+” between each intermediate destination to insert one.
 ![image](https://forum.kurviger.com/uploads/default/original/3X/b/2/b21b51a7c3c1dd98dcd3d6fb5741ce0e8113a048.png)
I could also very well imagine the idea of avoidances between the intermediate destinations. Shaping points wouldn’t need to be taken into account there. But that isn’t such a high priority for me. I can generally manage well enough with a few shaping points. Those are quickly added.
**Author:** ![Toffel](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/t/9dc877/32.png) [@Toffel](https://forum.kurviger.com/u/Toffel)\
**Post date:** [November 6, 2026, 11:14pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/29 "2026-11-06T23:14:48Z")
</div>
> [@schippy](#):
> I’m missing the ability to insert a new waypoint between the start and destination now.
> [@dingesd](#):
> Previously one click and the intermediate line was right where you want it, today it’s added as a destination at the bottom, you have to move it around awkwardly and then also look for the collapsed shaping etc.
Did that work in the web planner before? I plan so little in the web planner and genuinely don’t know. I’m unsure if the behavior was changed there.
In the app, you’ve never been able to insert something into the waypoint list; you could only append it to the end. So search for the address, then insert it as a shaping point or intermediate destination. Alternatively, click on the map. Then the point is intelligently inserted into the waypoint list. I’ve never had to sort anything.
**Author:** ![Hampic](https://forum.kurviger.com/user_avatar/forum.kurviger.com/hampic/32/7313_2.png) [@Hampic](https://forum.kurviger.com/u/Hampic)\
**Post date:** [November 6, 2026, 11:28pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/30 "2026-11-06T23:28:33Z")
</div>
> [@dingesd](#):
> Used to be one click, the intermediate line was right where you wanted it to be, today it is added as a destination at the bottom, you have to move it clumsily and then also the collapsed ones
Could it be that you selected the option for route extension on mouse click in the settings?
**Post date:** [November 7, 2026, 7:12am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/31 "2026-11-07T07:12:53Z")
</div>
> [@Andy\_Kreft](#):
> I can call up the route, but changing it is not possible without a calculation timeout
This error also appears when there is an issue with a single point. Here is the relevant part of the route (he sent it to me):
> **[Norge SN](https://kurviger.com/de/plan?point=70.370186%2C31.10772&pc.0=search_result&padr.0=Vard%C3%B8%2C%20%209950%20Norwegen&point=70.173081%2C28.555125&shaping.1=true&pc.1=search_result&padr.1=Esso%20Varangerbotn%2C%20S%C3%A1ttov%C3%A1rgeainu%20Vuonnabahta%20-%20Varangerbotn%20Norwegen&point=69.790298%2C30.793498&shaping.2=true&pc.2=search_result&padr.2=Grense%20Jakobselv%2C%20Grense%20Jakobselv%20veien%20S%C3%BCd-Varanger%20Norwegen&point=69.725415%2C30.041252&shaping.3=true&pc.3=search_result&point=70.173081%2C28.555125&shaping.4=true&pc.4=search_result&padr.4=Esso%20Varangerbotn%2C%20S%C3%A1ttov%C3%A1rgeainu%20Vuonnabahta%20-%20Varangerbotn%20Norwegen&point=70.015799%2C27.403765&pc.5=search_result&padr.5=Sirma%2C%20Deanugeaidnu%20Sirbm%C3%A1%20-%20Sirma%20Norwegen&weighting=curvaturefastest&details=route_information&details=tomtom_incident&details=max_speed&details=street_name&document_title=Norge%20SN)**
> Entfernung 536 km | Dauer 9 h 38 min | Höhe ↗ 7.057 m ↘ 7.019 m
 ![image](https://forum.kurviger.com/uploads/default/original/3X/c/f/cf2abb210c52b79e37fe641f16257a80e9956895.jpeg)
Point 3 has a problem in this route. In the faulty version, the point was located a bit further to the right. You can still reproduce this now: If you move P3 in this example to the right towards the parking sign,
 ![image](https://forum.kurviger.com/uploads/default/original/3X/1/f/1f0137bfcf9db0602511255ca2444313f21b8cc3.jpeg)
a timeout error occurs. Then the route is gone, and you can neither share nor split it. If you move the point back to the gas station, everything works again. With a route that consists of 300 shaping points and is 12,000 km long, you have quite a bit of work finding this error.
Since @Andy_Kreft writes that there was no problem with the previous version, it might have something to do with the update, and I am leaving this post in this thread.
Addendum:
When I tried to insert the 12,000 km file as an overlay, it complained:
 ![image](https://forum.kurviger.com/uploads/default/original/3X/f/0/f046bcd2ecc463e8a9a2e364de8beeea51f8d036.png)
Well, it is a bit long after all.
**Author:** ![Markus\_S](https://forum.kurviger.com/user_avatar/forum.kurviger.com/markus_s/32/28938_2.png) [@Markus\_S](https://forum.kurviger.com/u/Markus_S)\
**Post date:** [November 7, 2026, 8:30am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/32 "2026-11-07T08:30:36Z")
</div>
Still works for me in the browser on my iPad.
Unfortunately, the screen recording (26 seconds) cannot be uploaded.
Therefore, 4 screenshots from the clip.
SP2 was added in the correct place.
 ![ScreenRecording_11-07-2026 09-21-57_1_still](https://forum.kurviger.com/uploads/default/original/3X/b/3/b3ef300a5a2ded2ad12e0ed70abbd3e285665171.jpeg)
 ![ScreenRecording_11-07-2026 09-21-57_1_still](https://forum.kurviger.com/uploads/default/original/3X/1/c/1c66237528ea5a06e012db182ae27da36dacb33f.jpeg)
 ![ScreenRecording_11-07-2026 09-21-57_1_still](https://forum.kurviger.com/uploads/default/original/3X/2/9/29214a43cfcb06f1ed795a51d4808b1c348b882e.jpeg)
 ![ScreenRecording_11-07-2026 09-21-57_1_still](https://forum.kurviger.com/uploads/default/original/3X/1/6/16e2476c2f0c923725718c0607289fc4f07bc104.jpeg)
**Post date:** [November 7, 2026, 8:33am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/33 "2026-11-07T08:33:27Z")
</div>
> [@Maxx18](#):
> you have a bit of work to find this error.
Night shift? Phew. Either that’s OSM or 3.6.7 with map updates. I wouldn’t expect to see that here.
I can manage it with shaping points — and even then only occasionally. When going back and forth, Kurviger shows duplicate lanes. I can’t see those on OSM.
Could it be that the routing finds the parking lot, but no way back out?
 ![ScreenMaster_20261107_091055](https://forum.kurviger.com/uploads/default/original/3X/7/8/78b8a64f805f5a530ca46fc0ab811450c8db191a.png)
Could something have been deleted in OSM while Kurviger isn’t up to date yet? An OSM expert needs to take a look to confirm or rule that out. Are lanes overlapping?
**Author:** ![Serpentinenfanatiker](https://forum.kurviger.com/user_avatar/forum.kurviger.com/serpentinenfanatiker/32/4430_2.png) [@Serpentinenfanatiker](https://forum.kurviger.com/u/Serpentinenfanatiker)\
**Post date:** [November 7, 2026, 1:45pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/34 "2026-11-07T13:45:53Z")
</div>
I don’t know if this is just happening to me.
I opened the new version in the web browser for the first time.
Lo and behold, I’m not being asked if I want to open the last route.
Has this been intentionally removed?
I often plan quickly in between things and then have to leave. But in the end, I wasn’t able to finish the last route.
So after a week, when I didn’t find the time, opening it again and continuing from there is no longer possible.
To get around, i.e., to have a certain structure, my cloud folders are sorted by name.
Am I now supposed to go through every single route in the folder to find the one with the last change, or keep sorting and then sorting back just to find my way around, or is it just not working for me right now?
**Post date:** [November 7, 2026, 2:15pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/35 "2026-11-07T14:15:01Z")
</div>
> [@Serpentinenfanatiker](#):
> Lo and behold, I am not being asked if I want to open the last route.
> Has this been removed deliberately?
That only happens the first time you visit the updated website. You will still be asked. You can test it out really quickly.
**Author:** ![hubertusw](https://forum.kurviger.com/user_avatar/forum.kurviger.com/hubertusw/32/22505_2.png) [@hubertusw](https://forum.kurviger.com/u/hubertusw)\
**Post date:** [November 8, 2026, 11:21am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/36 "2026-11-08T11:21:28Z")
</div>
From my point of view, you’ve missed a change to clean-up. After you’ve planned and saved a route, you still have to click ‘Delete Route’, which IIMHO is very misleading. To my understanding ‘Delete Route’ would remove the saved route from the cloud storage. What the command ‘Delete Route’ actually does is to close the current plan and clear the screen for another plan. Why don’t you call it like that?
**Author:** ![Moto\_Club](https://forum.kurviger.com/user_avatar/forum.kurviger.com/moto_club/32/32388_2.png) [@Moto\_Club](https://forum.kurviger.com/u/Moto_Club)\
**Post date:** [November 8, 2026, 5:02pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/37 "2026-11-08T17:02:20Z")
</div>
Red flag on this new update : cut function is no more avaliable. It was one of my favorite… Please, put it back !!!
 ![image](https://forum.kurviger.com/uploads/default/original/3X/7/b/7ba5b372ecd372b0d065903c2c9821b0f175a526.png)
**Post date:** [November 8, 2026, 5:12pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/38 "2026-11-08T17:12:09Z")
</div>
> [@Moto\_Club](#):
Check _Options_ in the waypoint list.
 ![ScreenMaster_20261108_181149](https://forum.kurviger.com/uploads/default/original/3X/f/c/fc859125c23f7e2d67a71fec345fd9f7d1898fd3.jpeg)
Btw: I saw it is also available in the version for _Touch Devices_, very likely to be available in the app as well. Additional the option to change the startpoint for roundtrips. Cool. 👍
 ![ScreenMaster_20261108_181540](https://forum.kurviger.com/uploads/default/original/3X/f/a/fad4c7e478ecb3861c78bae24ea71f280bd37c3b.jpeg)
**Mobile View - Header infromation of diagrams**
No matter which diagram is used, the header is bold and always _Elevation_. The header of the current view (here: Speed limit) hides at the bottom. My eyes are catched by the top information and must search the infomation at the bottom.
Is it possible to switch the information?
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/3/c/3cd51e1524fb96f407def04562eccc61e9454146.jpeg)
**Post date:** [November 8, 2026, 5:28pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/39 "2026-11-08T17:28:31Z")
</div>
> [@Hampic](#):
> That only happens the first time you load the modified webpage. You will still be asked. You can quickly test it out yourself.
Thanks, it actually is like that.
Everything is perfect.
The eye has to get used to it. Now the km and time are smaller to fit in the elevation gain. The latter is completely uninteresting to me, but at least I can still read it on my large monitor and, as I said, once I get used to it, I’ll find it quickly again.
**Post date:** [November 8, 2026, 5:45pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/40 "2026-11-08T17:45:28Z")
</div>
Just ideas, no answer required.
**Web and Mobile View - Speed-limit**
In the view for speed limits, the first box is a text box, which musst be scrolled in case there are three or more lines. On small screens hard to handle and does not look nice, imho.
In contrast the OSM-data below is a dynamic table with lines. Coul the first box not be handled equally as the OSM data, as this is as far as I can see, just an extract of the OSM data.
Addtional: The full OSM data can be quite long. It would be nice, it could be hidden / shown for example by making the +OSM-ID+ clickable or something following your style.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/b/4/b4deafb29429eba2f3d30b4431af8bbae3304904.png)
**Tiny font and Visibility of Avoidances**
This tiny font is unique as far as I can see. The curvature has a big and clear icon, everybody can learn and chooses curvature once for a route, but we see also the text. The avoidances are from my point more important to see. These icons are very tiny and addtional the full set of avoidances is hidden (+5).
Idea: What if the two buttons are combined into one button _Route Settings_. The header in same font like _New Route_ above. The icons could be combined, perhaps separated by a “|”.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/a/3/a374cd2fe477742160c3e17e39747400716e6444.jpeg)
Instead of two single popup dialogues for Curvature and Avoidances there could be a combined dialogue with tabs like this, one tab _Curvature_ and second tab _Avoidances_.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/5/3/536b61483ceb9bad1dfb2c74c01181c04140bbc2.png)
Btw: Great to have the option to _Show/Hide all_ in Overlays.
**Mobile View - Card Speed-Limits**
I would prefer speed limits sorted by speed and not by percentage.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/2/f/2fbfb10c63851fb5be27518cb8b0eb13976a7ed8.jpeg)
**Mobile View - Avoidance and Curvature - Popup**
There are four ways to close. Proposal: remove the blue button to close. Same for _Adjust Curvature_ from waypoint-list.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/a/4/a4549edc8e070b105a5fa9311319a4bc072c273a.jpeg)
**Functions Web versus Mobile**
In the Web-Planner I have additional entries _Show turn instructions_ and _Show entire route_.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/2/4/24e58bd16060f055c261cc20d770634fca641288.jpeg)
I cannot see or find these in the mobile view. Ok, as we cannot export the roadbook from mobile view, it is surely not that important. The _Show entire route_ would be nice.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/f/3/f3fc08b03f36dfda15ba349bb8ee4b2ba1386494.jpeg)
[Previous page](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879.md?page=1)
[Next page](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879.md?page=3)
