# New route planning UI | Neue Routenplanungs-UI
**URL:** <https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879>\
**Category:** News and Updates about Kurviger\
**Tags:** web-version\
**Created:** [November 5, 2026, 12:12pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879 "2026-11-05T12:12:39Z")\
**Posts on this page:** 20\
**Page:** 4
<div class="post-metadata">
**Author:** ![JoergH](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/j/e47c2d/32.png) [@JoergH](https://forum.kurviger.com/u/JoergH)\
**Post date:** [November 11, 2026, 9:25am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/61 "2026-11-11T09:25:07Z")
</div>
Or just click on “6 Shaping Points” again. Or am I missing something?
**Author:** ![Maxx18](https://forum.kurviger.com/user_avatar/forum.kurviger.com/maxx18/32/7016_2.png) [@Maxx18](https://forum.kurviger.com/u/Maxx18)\
**Post date:** [November 11, 2026, 9:52am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/62 "2026-11-11T09:52:20Z")
</div>
That would be like before: by clicking on the next point, you can see the distance and time to the next point. But if you want to know how far it is to point 10, you have to click multiple times and add up the km/times in your head. With the “Distance to other waypoints” list, that is wonderfully easy.
**Author:** ![Klaus-Peter](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/k/48db29/32.png) [@Klaus-Peter](https://forum.kurviger.com/u/Klaus-Peter)\
**Post date:** [November 11, 2026, 10:57am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/63 "2026-11-11T10:57:55Z")
</div>
Under the “Windingness” settings
 → Fastest
 → Extra Winding
 → Winding
the route calculates for me, but for the rest it doesn’t
**Author:** ![Kira](https://forum.kurviger.com/user_avatar/forum.kurviger.com/kira/32/23135_2.png) [@Kira](https://forum.kurviger.com/u/Kira)\
**Post date:** [November 11, 2026, 11:39am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/64 "2026-11-11T11:39:13Z")
</div>
Thanks to everyone for the feedback. We are definitely reading along and appreciate your input!
Thanks for the bug report, I’ve passed that on. Regarding further ideas and suggestions, we’ve definitely taken them on board, even though of course not everything will be changed accordingly.
> [@Venomin](#):
> Is there a release date for the new mobile Planner?
We’re reluctant to give that out, as things can still change dynamically and we’d rather surprise you with an “earlier than thought” release than disappoint you with a delay 😉
> [@bios4](#):
> Why is there still an extra “Follow route standard” toggle after clicking the “Change curviness” button when adjusting the curviness between two waypoints?
I don’t quite understand the confusion here yet. How do you understand “route standard”?
> [@Maxx18](#):
> If you click on a spot in the chart
> ![image](https://forum.kurviger.com/uploads/default/original/3X/6/4/64578d2c0c8b4a259ac5a259e68833a77610abeb.png)
> the map zooms in and shifts to that spot.
[Do you perhaps mean this feature?](https://youtu.be/O1ehGcro1_4?si=o7OGwthowJ45Z_20&t=312)
> [@Klaus-Peter](#):
> The solution is quite simple, just click on the gray line in the expanded list
Or click on the blue text “X Shaping Points”. Thanks for the feedback, that might need to be made easier to find (perhaps even when expanding?).
**Post date:** [November 11, 2026, 12:17pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/65 "2026-11-11T12:17:32Z")
</div>
> [@Kira](#):
Ah, I see! Thanks for the tip! That’s why it sometimes worked and sometimes didn’t: Because when it worked, I hadn’t just clicked, but had also coincidentally highlighted a tiny bit with the mouse button held down.
**Post date:** [November 12, 2026, 12:41pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/66 "2026-11-12T12:41:38Z")
</div>
Thank you so much for all the feedback! We’ve worked on a few more topics, fixed some additional bugs, and polished the overall behavior.
Here are some of the things we’ve changed:
> [@Thoka](#):
> ![image](https://forum.kurviger.com/uploads/default/original/3X/8/6/865b32901a672d5e267b7f0163ce9416e53ab0b0.png)
The waypoint list can now also be used on mobile devices when no waypoints or only start/destination have been set. To do this, simply swipe up from the bottom.
- Remembering the position in the waypoint list when collapsing or returning from the waypoint
- Curviness options between waypoints close upon selecting an option
- Preview when overlay styling
> [@Maxx18](#):
> Speaking of the speed limit display: If you click on one of the signs in the speed limit display on the map, say 50,
> ![image](https://forum.kurviger.com/uploads/default/original/3X/e/f/efde81ccd0f3a351d6e42f1d3a2bc7cd8381d866.png)
> and then close the left info window using the X, the map view changes and the speed limit display disappears. To make it visible again, you have to select a different view in the elevation profile and then select speed limit again.
We have adjusted that.
> [@Toffel](#):
> This remains if I set the destination first.
We’ve adjusted that 👍
> [@Toffel](#):
> **Mobile View - Card Speed-Limits**
> I would prefer speed limits sorted by speed and not by percentage.
Are now sorted 👍
> [@GuG](#):
> I’m using Kurviger in the web version on a 12-inch Lenovo tablet. What works in the app—setting the start, destination, and waypoints by long-pressing on the map and then making a selection—is not possible in the web version.
Does this problem still exist after today’s update? If so, do you have more info for us? On a touch device, tapping the map should be enough, and on desktop devices, a right-click.
> [@schippy](#):
> I’m now missing the option to insert a new waypoint between start and destination.
> Now I have to move the points with every via point.
> It would be great if there was a “+” between every via point to insert one.
Can you explain that in more detail? When and why do you need the +? When you add a point via search or the map, it usually gets sorted into the right place automatically, doesn’t it? Or are you trying to do something else?
How do the features work for you now?
**Author:** ![l.helsing](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/l/f475e1/32.png) [@l.helsing](https://forum.kurviger.com/u/l.helsing)\
**Post date:** [November 12, 2026, 2:52pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/67 "2026-11-12T14:52:15Z")
</div>
I use the web version for planning and I really agree on this one. I use Kurviger to plan longer trips through Europe and usually have 100-200 waypoints for the whole trip. The pervious version had this nice function where one could add a waypoint between two earlier created waypoints. In the new version the new waypoint are created in the end of the list which is no problem for shorter routes but not very convenient for longer routes.
**Author:** ![schippy](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/s/e495f1/32.png) [@schippy](https://forum.kurviger.com/u/schippy)\
**Post date:** [November 12, 2026, 2:58pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/68 "2026-11-12T14:58:25Z")
</div>
> [@boldtrn](#):
> Could you explain that in more detail? When and why do you need the +? If you add a point via search or the map, for example, isn’t it usually sorted correctly anyway? Or do you want to do something else?
I hadn’t thought of the search at the very top, but had only paid attention to the red-bordered area for planning:
 ![image](https://forum.kurviger.com/uploads/default/original/3X/3/d/3d6e450fdaae56417caf3332d26a0146893ad7df.png)
Then I clicked on “New Waypoint” (which should rather be called “New Destination” or “Extend Route”). I was aware of inserting via the map. But not the search, which is visually located somewhat outside the area for route inputs.
 ![image](https://forum.kurviger.com/uploads/default/original/3X/f/4/f4d28a55b64c8577ffff7a7e65ef026cd1a19281.png)
If you insert the via-points via the search, it usually does it correctly. But not always (in case it goes a few km in the wrong direction and you don’t want automatic optimization).
Once you know it, it’s fine this way. But I don’t find it 100% intuitive in connection with the layout when the location search is in the “menu area”.
A “+” between the waypoints to insert new waypoints would be more intuitive for me.
**Author:** ![Mario\_K](https://forum.kurviger.com/user_avatar/forum.kurviger.com/mario_k/32/23261_2.png) [@Mario\_K](https://forum.kurviger.com/u/Mario_K)\
**Post date:** [November 12, 2026, 8:39pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/69 "2026-11-12T20:39:29Z")
</div>
a bit hidden, but implemented even better than I wanted — outstanding!! 👍
**Author:** ![Toffel](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/t/9dc877/32.png) [@Toffel](https://forum.kurviger.com/u/Toffel)\
**Post date:** [November 13, 2026, 8:06pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/70 "2026-11-13T20:06:24Z")
</div>
> [@boldtrn](#):
> How are the features working for you now?
My favorite even on the phone 🙂
I wouldn’t be myself .. I turned off all hints on the web. How do I get back to this setting in the web version? Deleting local data doesn’t help. I was able to reactivate everything on the phone in the browser via the “Hints” tab.
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/b/f/bfdc946a9ef08933c9f2d968b99649e8cf1f15ec.jpeg)
**Post date:** [November 14, 2026, 9:40am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/71 "2026-11-14T09:40:58Z")
</div>
Everything is fine with my web test
Load route, scroll waypoint list all the way down, click 3 open hints
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/a/5/a53047b8be98ade2cd084e043ff93fde42898a5a.png)
Click edit hints
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/c/7/c706f9971e8efa4fc9c64aafc7c294a14ff58876.jpeg)
Voilá
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/8/e/8e443778bca4cc28e1be5874afe122da247f625d.jpeg)
**Post date:** [November 14, 2026, 9:58am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/72 "2026-11-14T09:58:03Z")
</div>
> [@JoergH](#):
> Voilà
Turn them all off.
**Post date:** [November 14, 2026, 10:05am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/73 "2026-11-14T10:05:25Z")
</div>
True, if the “open hints” button is missing
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/a/d/ad49395d3a22d0640a7402f121a928f2ed51cbfe.png)
the “customize hints” input mask can no longer be opened 🧐
**Post date:** [November 14, 2026, 10:13am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/74 "2026-11-14T10:13:07Z")
</div>
> [@JoergH](#):
> the input mask “Customize notes” can no longer be opened 🧐
Ok, that tip was mean of me 😅 . The solution is above, you can fix it with a tablet or smartphone. Basically, there should be a link in the window with a note “No notes” 🙃.
**Post date:** [November 14, 2026, 10:25am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/75 "2026-11-14T10:25:22Z")
</div>
alternatively, load another route that has an open hint
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/f/6/f6b969ab48ca4dedd04490ed47c170eeff60f3e8.png)
then the customize hints field will be available again
 ![grafik](https://forum.kurviger.com/uploads/default/original/3X/0/7/07f0d4a3f9af8f584725eefecbe2ed0f35ff5c54.png)
😁 Trial and error makes you smarter.
**Author:** ![GuG](https://forum.kurviger.com/letter_avatar_proxy/v4/letter/g/76d3ee/32.png) [@GuG](https://forum.kurviger.com/u/GuG)\
**Post date:** [November 14, 2026, 4:38pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/76 "2026-11-14T16:38:22Z")
</div>
Planning in the web version with Lenovo tablet is working again 👍.
**Author:** ![Viola](https://forum.kurviger.com/user_avatar/forum.kurviger.com/viola/32/12413_2.png) [@Viola](https://forum.kurviger.com/u/Viola)\
**Post date:** [November 15, 2026, 8:38am UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/77 "2026-11-15T08:38:36Z")
</div>
Split this topic on November 15, 2026, 8:38am UTC
A post was merged into an existing topic: [In next versions would you take trafic into account ?](https://forum.kurviger.com/t/in-next-versions-would-you-take-trafic-into-account/27868/3)
**Author:** ![SPKELLER](https://forum.kurviger.com/user_avatar/forum.kurviger.com/spkeller/32/7739_2.png) [@SPKELLER](https://forum.kurviger.com/u/SPKELLER)\
**Post date:** [November 16, 2026, 6:00pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/78 "2026-11-16T18:00:26Z")
</div>
@boldtrn … am missing the “+” as well. I have a rout with quite a few waypoints and shaping points and it is quite cumbersome to add waypoints or shaping points.
If I click “add waypoint” the empty box appears at the very end of the list as the new final destination, which increas my tour by approx 1000 km.
Taake the picture as an example.. How can I now add a waypoint OR a shapingpoint between WP166 and SP167?
 ![kurviger WP problem](https://forum.kurviger.com/uploads/default/original/3X/6/0/60cd4f4902276d3df74184694f7b636f648e982a.jpeg)
**Post date:** [November 16, 2026, 6:52pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/79 "2026-11-16T18:52:34Z")
</div>
> [@SPKELLER](#):
> How can I now add a waypoint OR a shaping point between WP166 and SP167?
The fastest way to do this is by right-clicking on the desired spot on the map.
 ![image](https://forum.kurviger.com/uploads/default/original/3X/d/0/d0e0ac8592c2889abd7df98a7869e25260eed062.png)
**Post date:** [November 16, 2026, 7:19pm UTC](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879/80 "2026-11-16T19:19:23Z")
</div>
THX. What, if I need to add a very specific address? Have to zoom in the map and aim at the adress?
[Previous page](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879.md?page=3)
[Next page](https://forum.kurviger.com/t/new-route-planning-ui-neue-routenplanungs-ui/27879.md?page=5)
