# OSM - Kartenfehler
**URL:** <https://forum.kurviger.com/t/osm-kartenfehler/7497>\
**Category:** OSM\
**Created:** [February 6, 2022, 10:40pm UTC](https://forum.kurviger.com/t/osm-kartenfehler/7497 "2022-02-06T22:40:21Z")\
**Showing post:** 55
**Author:** ![rumbrummer](https://forum.kurviger.com/user_avatar/forum.kurviger.com/rumbrummer/32/113_2.png) [@rumbrummer](https://forum.kurviger.com/u/rumbrummer)\
**Post date:** [August 14, 2023, 6:21am UTC](https://forum.kurviger.com/t/osm-kartenfehler/7497/55 "2023-08-14T06:21:47Z")
> [@Basti](#):
> Da steht doch eine Schranke. Sollte Kurviger bzw. OSM jetzt nicht allarm schlagen?
Stimmt, Scbranke ist noch da:
> **[Node: 612923508](https://www.openstreetmap.org/node/612923508#map=18/43.46799/12.72666)**
> OpenStreetMap is a map of the world, created by people like you and free to use under an open license.
@boldtrn : Wieso routet Kurviger dort durch?
> **[The Best Motorcycle Route Planner - Plan your next Tour | Kurviger](https://kurviger.com/?point=43.468284%2C12.726049&point=43.468185%2C12.727542&vehicle=motorcycle&weighting=curvature&additional_weighting=&details=route_information&details=max_speed&details=street_name&additional_weighting_factor=2&avoid_toll_roads=false&avoid_toll_roads_factor=5&avoid_ferries=false&avoid_ferries_factor=5&avoid_motorways=false&avoid_motorways_factor=5&avoid_main_roads=false&avoid_main_roads_factor=3&avoid_small_roads=false&avoid_small_roads_factor=4&avoid_unpaved_roads=false&avoid_unpaved_roads_factor=5&route_collection_id=QAJ6OB2O1V6BZPBByLir)**
> Plan your motorcycle trips with Kurviger. Kurviger prevers curvy roads, while avoiding cities and motorways. Find the best roads for your motorcycle tour.
Edit: Die Schranke wird als “potenziell gesperrt” angezeigt (da scheint sich was geändert zu haben, habe ich nicht mitbekommen).
Auf der Karte wird es nicht angezeigt - evtl. weil es durch die “unbefestigte Str.” Info überdeckt wird:
 ![barrier](https://forum.kurviger.com/uploads/default/original/2X/b/b1e0bbb71acca38f4c67008994dc390ed668b2b2.jpeg)
Edit#2: Im Alter wird man vergeßlich 😇 😇
> [@Handle barriers like potentially closed roads?](https://forum.kurviger.com/t/handle-barriers-like-potentially-closed-roads/7274/5):
> This has been implemented, also see here: [https://forum.kurviger.com/t/routing-server-update-to-graphhopper-5-3-unblock-gates/9457](https://forum.kurviger.com/t/routing-server-update-to-graphhopper-5-3-unblock-gates/9457)
Wenn die Schranke wirklich zu / gesperrt ist, sollte sie meiner Meinung nach in OSM z.B. mit motor\_vehicle=no getagged werden (Fahrräder, Fußgänger und Reiter sind laut OSM ja erlaubt)
_[View the full topic](https://forum.kurviger.com/t/osm-kartenfehler/7497)._
