when pressing enter in a form field of a waypoint the form should submit the data (and in this case trigger the search) but it does not. Tested in Firefox and Chrome
Two reasons why I feel like this is a bug and post it here as such:
It works when selecting a suggestion from the dropdown (if I start typing “Berlin” for example and then select the city with the down arrow and then press enter, it submits)
Looking at the code, the input field hast type=text set, which should auto-submit on enter, and the search button is inside the form tag and has type=submit. So I don’t even really see the bug you’re having, from a very quick glance… it should work
By the way… Why don’t we have a “bug-report” tag here in the forum?
That’s actually something different - at least from a technical perspective it’s not a form submit
The reason could be that it’s an autocomplete which could break how the browser handles the enter event. It would be interesting to find out though.
At first we had a bug report category here in the forum, but nobody used it, so we removed it. I think issue/problem should be enough or do you think a bug tag would further help?
