# Suggestion: route options between waypoints
**URL:** <https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482>\
**Category:** Route planning\
**Created:** [November 23, 2019, 11:32am UTC](https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482 "2019-11-23T11:32:05Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jan\_Lorenzen](https://forum.kurviger.com/user_avatar/forum.kurviger.com/jan_lorenzen/32/1148_2.png) [@Jan\_Lorenzen](https://forum.kurviger.com/u/Jan_Lorenzen)\
**Post date:** [November 23, 2019, 11:32am UTC](https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482/1 "2019-11-23T11:32:05Z")
</div>
Not sure if this the right place to add this suggestion, but here goes…
One thing I keep missing when trying to plan longer routes, is the possibility to set route options between way points and not only for the entire route.
For example:
I need to plan a route from Denmark to Schwerin in Germany, and I would like to include motorway or main roads for a part of the tour but far from all of it.
If I deselect motorway/main roads in order to find good curvy small roads or the other way round then I find it tricky to make a good overall tour.
EDIT: Could it be done for example by setting route options for way point collections 1-5, 5-8, 8-15, 15-n?
Alternatively:
Is it possible to make a route from other smaller routes, that have been made and then “merge” them together into a single route?
Best regards,
Jan
**Post date:** [November 23, 2019, 12:01pm UTC](https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482/2 "2019-11-23T12:01:58Z")
</div>
Thanks for the proposal.
Different routing profiles within one route are currently not supported.
But there is open a feature topic, so we plan to see it in the future. 🙂
> [@Website: Multiple route profiles](https://forum.kurviger.com/t/app-website-use-of-different-routing-profiles-within-one-route/1157):
> Hello community, As an Garmin user for years who´s looking for an non properitary alternative, I found Kurviger. While generating first own routes I try to use different routing profiles for different sections of one route in a way fastes route from WP 1 to WP 2 (to reach the interesting area fast by using highways e.g.) and from WP 2 to WP 3, 4, 5 etc. using curvy route profile to have fun and from WP 5 back to WP1 (6) again using fast route profile to go home. Till now I can´t find this fea…
**Post date:** [November 23, 2019, 12:21pm UTC](https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482/3 "2019-11-23T12:21:09Z")
</div>
Thank you for the fast response.
Would it be tricky to implement merging of routes?
Pretty much like selecting several maps to open, you would select (sub-)route files in order.
Kurviger would then connect the subroutes.
End point of route 1 would be automatically connected to start point of route 2 using the active route settings… End of to start of 3… Etc. Etc.
**Post date:** [November 23, 2019, 12:38pm UTC](https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482/4 "2019-11-23T12:38:11Z")
</div>
> [@Jan\_Lorenzen](#):
Routes can have too many options (besides profiles), so it’s not straightforward.
So it’s more related or after the multiple routing profiles within one route feature.
Currently the one active route can have one profile and specific routing options.
**Author:** ![zaphod\_42](https://forum.kurviger.com/user_avatar/forum.kurviger.com/zaphod_42/32/499_2.png) [@zaphod\_42](https://forum.kurviger.com/u/zaphod_42)\
**Post date:** [November 24, 2019, 12:49pm UTC](https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482/5 "2019-11-24T12:49:19Z")
</div>
> [@devemux86](#):
But you can change it anytime while driving. Unfortunatly we can’t simulate it because simulation begins always at “Start”. I tested it in “real life” - see:
> [@Website: Multiple route profiles](https://forum.kurviger.com/t/app-website-use-of-different-routing-profiles-within-one-route/1157/13):
> Du kannst doch jederzeit in der APP von “kurvig” auf “schnell” umsteigen. Also: Planung mit z. B. “extra kurvig” dabei nur den Teil “planen”, der auch so gefahren werden soll - Anfahrt und Heimfahrt planerisch ignorieren. Beispiel: [https://kurv.gr/KKbOL](https://kurv.gr/KKbOL) Von Start bis WP1 (Oberau) = Anfahrt (Autobahn) Von WP1 bis WP7 (Irschenberg) = “Tour” Von WP7 bis Ziel = Heimfahrt (Autobahn) Vorm Start in der APP Routing auf “schnell” setzen und am WP1 ändern auf “extra kurvig”, dann am WP7 wiederum auf…
**Post date:** [November 24, 2019, 12:55pm UTC](https://forum.kurviger.com/t/suggestion-route-options-between-waypoints/2482/6 "2019-11-24T12:55:29Z")
</div>
> [@zaphod\_42](#):
If mean the navigation simulation, can start simulation anywhere on route via ⏪ ⏩ buttons.
> [@App: Navigation simulation](https://forum.kurviger.com/t/app-simulate-navigation-function/2062/10):
> Play / Pause navigation simulation play_or_pause_buttonSkip Previous / Next turn instructions rewind fast_forwardSkip to route Start / End (long press) rewind fast_forwardSelect simulation speed (tap speed panel) Works nicely with [https://forum.kurviger.com/t/app-smooth-movement/2450](https://forum.kurviger.com/t/app-smooth-movement/2450) [Kurviger]
