# Temporary route modif to next gas station
**URL:** <https://forum.kurviger.com/t/temporary-route-modif-to-next-gas-station/2081>\
**Created:** [July 29, 2019, 6:04pm UTC](https://forum.kurviger.com/t/temporary-route-modif-to-next-gas-station/2081 "2019-07-29T18:04:38Z")\
**Showing post:** 6
**Post date:** [July 30, 2019, 1:18pm UTC](https://forum.kurviger.com/t/temporary-route-modif-to-next-gas-station/2081/6 "2019-07-30T13:18:33Z")
> [@lve0200](#):
> in dense areas, as you show in the screenshot, there’s usually no issue, but this is an intern. APP and in central France, North-Spain or Greece, it’s much different!
As you can see in @linux-user screenshot above, the app shows roughly an area of 20x40km and still showing fuel stations. Depending on your screen resolution, you might be able to even show a bigger area. On my device I can show roughly a 30x60km rectangle and still see the fuel stations. You will have to select the fuel station map layer.
Adding an option to show POIs along the route (like the fuel station) have been discussed for example here: [Extended search function for Food and Fuel](https://forum.kurviger.com/t/extended-search-function-for-food-and-fuel/780)
That’s probably what you are asking?
_[View the full topic](https://forum.kurviger.com/t/temporary-route-modif-to-next-gas-station/2081)._
