# This.\_map is null
**URL:** <https://forum.kurviger.com/t/this-map-is-null/3711>\
**Category:** Website\
**Tags:** solved\
**Created:** [July 3, 2020, 8:59am UTC](https://forum.kurviger.com/t/this-map-is-null/3711 "2020-07-03T08:59:59Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Tom](https://forum.kurviger.com/user_avatar/forum.kurviger.com/tom/32/168_2.png) [@Tom](https://forum.kurviger.com/u/Tom)\
**Post date:** [July 3, 2020, 8:59am UTC](https://forum.kurviger.com/t/this-map-is-null/3711/1 "2020-07-03T08:59:59Z")
</div>
I just reloaded any tour… then when trying to insert a shaping point
 ![grafik](https://forum.kurviger.com/uploads/default/original/2X/4/40b9be9ffd362d13f5abebe0101c9f0d505b4d88.jpeg)
it directly comes up with this error
 ![grafik](https://forum.kurviger.com/uploads/default/original/2X/8/8a490112d34964b2c90bb12676da45cfe7c4ef1f.jpeg)
with MS EDGE when I try to login in my account for [kurviger.de](http://kurviger.de) this error appears directly… so I can’t login into my gmail account in Kurviger when using MS Edge
 ![grafik](https://forum.kurviger.com/uploads/default/original/2X/7/76f1af7030cc70bb9627b61cef8e9a6df1d3a3cb.png)
But in MS Edge I can import a route and then adding a wp or a shaping point works without error message
**Post date:** [July 3, 2020, 12:35pm UTC](https://forum.kurviger.com/t/this-map-is-null/3711/2 "2020-07-03T12:35:40Z")
</div>
I moved this post, thanks a lot for creating that. I cannot reproduce the error this.\_map is null. It would be great if you could help me identify / reproduce the issue.
**Post date:** [July 4, 2020, 12:44pm UTC](https://forum.kurviger.com/t/this-map-is-null/3711/3 "2020-07-04T12:44:32Z")
</div>
I have delete the internet cache and tried again. I also couldn’t not simulate the errors again. It works now, so I guess it was a cache problem.
**Post date:** [July 6, 2020, 5:05am UTC](https://forum.kurviger.com/t/this-map-is-null/3711/4 "2020-07-06T05:05:10Z")
</div>
When I open [kurviger.de](http://kurviger.de) in MS Edge, I directly get this error message, but I can login and load and edit routes, so not a big issue.
 ![image](https://forum.kurviger.com/uploads/default/original/2X/0/0e53bef93e95f786f380d1a3388762872b075fea.png)
**Post date:** [July 6, 2020, 2:42pm UTC](https://forum.kurviger.com/t/this-map-is-null/3711/5 "2020-07-06T14:42:07Z")
</div>
> [@Tom](#):
Thanks for confirming!
> [@Tom](#):
That is a different error, if this happens again, please let us know, in a different thread 🙂.
