# Turn instructions differs from calculated route
**URL:** <https://forum.kurviger.com/t/turn-instructions-differs-from-calculated-route/2936>\
**Category:** Route planning\
**Tags:** routing, problem\
**Created:** [April 6, 2020, 8:16am UTC](https://forum.kurviger.com/t/turn-instructions-differs-from-calculated-route/2936 "2020-04-06T08:16:00Z")\
**Showing post:** 5
**Post date:** [April 6, 2020, 7:02pm UTC](https://forum.kurviger.com/t/turn-instructions-differs-from-calculated-route/2936/5 "2020-04-06T19:02:51Z")
> [@Patrick](#):
> Hint for everybody for the future: if you have a yellow bubble below your waypoint, that’s a big no-no. Because it means that the route “does something” below your waypoint
After waypoint types integration, the shaping points are those without instructions / yellow bubbles.
More details exist in the waypoint types feature topic:
> [@App: Waypoint types](https://forum.kurviger.com/t/app-waypoint-types/2821/3):
> Garmin uses the “shaping point” term and we can use it for the UI texts: [Garmin BaseCamp](https://support.garmin.com/en-US/?faq=POYXggoD3p19jQOwZCvFA6): Shaping points are any position along a route that will not alert you when you arrive. Shaping points do not contain arrival time or distance between points information. [Google Maps](https://developers.google.com/maps/documentation/javascript/directions#Waypoints): stopover (optional) indicates whether this waypoint is a actual stop on the route (true) or instead only a preference to route through the indicated location (false). Stopovers are true by default. [HERE Maps](https://developer.here.com/documentation/routing/dev_guide/topics/waypoints.html): A waypoint can b…
_[View the full topic](https://forum.kurviger.com/t/turn-instructions-differs-from-calculated-route/2936)._
