Moin,
I noticed that subway tracks are missing in the standard map view.
At least in Hamburg, the subway runs on viaducts through large sections of the city and is therefore a great landmark, especially for visitors ![]()
Here, the blue tracks are missing in the standard view.
Solid line = Above ground
Dashed line = Underground
Especially the underground ones. ![]()
Those aren’t needed, of course…
Hi @Hampic,
But that’s yet another piece of info on the map. And that makes me wonder whether that’s really all that important for a motorcyclist. ![]()
Well, S-Bahn, DB, and tram tracks can be found everywhere on the map (Hamburg, Cologne, Frankfurt, Berlin).
Those are definitely landmarks. Only the Hamburg U-Bahn is missing for some reason… ?
If you want to get out of the city as quickly as possible, even for a motorcyclist ![]()
For locals, it certainly doesn’t matter at all, but for visitors, it can be helpful,
for example at the Landungsbrücken.
The same spot:
Personally, I’m indifferent about it, there are way too many tourists there anyway.
It’s just a minor bug ![]()
We once discussed this topic regarding railway tracks, which were barely visible on the map, but were then rendered more prominently and fit very well as of today. They also occupy areas on the map that are almost never traveled by other vehicles.
And maps are meant for orientation, so one should weigh things carefully and not dismiss them too quickly as “clutter.” Displayed railway lines offer added value.
I (rarely) get over there
and that thing mostly runs underground, doesn’t it?
I don’t really feel like U-Bahn lines are missing from the map, but I also can’t say whether OSM data would allow distinguishing whether a section of the route happens to run above ground.
Here is Dortmund for comparison, U45 to the most beautiful stadium in the world:
Planning: Rails are there.
Navigation: Rails are there too. (1) U-Bahn / (2) Deutsche Bahn
OSM error? Or is Hamburg being bullied?
Clearly bullying ![]()
In the opening post I used a different map as an example, and everything is visible there,
Both above and below ground. This is clearly a bug in the standard map’s generation.
TopPlusOpen map:
Standard
Edit: Smartass mode ON: The U-Bahn in Hamburg is actually called „Hochbahn“ (elevated railway), because the first ring route through the city runs almost entirely on stilts. The operating company has been called „Hochbahn“ since 1911. Smartass mode OFF.
We really don’t like bullying, and since it’s a quick fix, we’ll take that on board ![]()
