Website, cant save route
what to do - on the website - if the “save route” button doesnt do anything ?
works fine in Germany , tested
Noope, your example ist empty.
aber über den Aufruf kann ich speichern.
Check the 3dot Menu. Also YouTube for Kurviger.
Save Route ist Always available. But there ist no spezified Button, ist ist in the Menue.
Hi @hanzani,
What do you mean with “doesn’t do anything”? Could you please explain in a little more detail what you did?
Also have a look here: Saving a Route to the Cloud
@Kira könnte es sein das er den Balken unten rechts einfach nicht sieht ? oder Übersieht ?
und drauf wartet das ne Dialogbox kommt ? oder dann im “falschen” Ordner danach sucht ?
solved :slight_smile: what I didnt know was you first have to create a folder to put it in lol. WIthout that the save button is inactive. thanks all!
@Kira - can you please check with the team, if a first install for a new user contains no folder for routes and if not, if it is feasible?
I made this proposal a long time ago. As far as I remember a default folder for favorites is created, but not for routes.
I think it said “no collection” at first, and because of that the button is in inactive, it was a bit confusing for me :slight_smile:
We checked: the cloud entails a first default route folder if you first install the app.
That makes perfect sense. It’s hard to tell from a distance exactly why there wasn’t a default folder for you. So thanks for your feedback, and we will keep an eye on that!
