There are turn instructions on waypoints too, so their names should be unmodified.
Or else at each import / export there will be added new prefixes (WPx WPx WPx…).
It is each app’s responsibility to add custom prefixes in its panels (if they’re needed).
In my Navigator 5 also ‘cmt’ and ‘desc’ of route points are ignored. It seems to use only the name, the coordinates and the point type (in extension: ViaPoint / ShapingPoint ).
I guess all newer Garmin devices are doing so - perhaps users of Zumo 59x, Zumo 39x, Zumo XL etc. can give further information here …
That was the reason for my proposal to put a hint in the name - it is the only item I can see on device.
A constant factor in applications with gpx is that there is almost no uniformity in applications.
Much of what is possible with the basic gpx standard is unfortunately sometimes not used.
Question:
Do you mean the Kurviger gpx export direct transfer to your Navigator device?
Or the Kurviger output always runs through the converter tool first?
The last:
If Kurviger gpx clearly indicates both Via or Shape by means of type the tool probably can 100% accurately convert such into the typical “in house” Garmin extension?
If Kurviger gpx puts extra info in or cmt or desc, your tool development may be able to convert into the name tag?
No?
my proposal was for direct use (without converter), I think most people using Kurviger GPX on a Garmin or an other navigation device do not use the converter.
You are right: Probably the converter will be able to read the information in the ‘cmt’, ‘desc’ or ‘sym’ also, that is no rocket science (but not yet implemented, of course).
Currently you can select a combination of .GPX and .kurviger files to get all information as described in last paragraph in
Sorry, my reply lead to misunderstanding → I expanded “Garmin” by “or an other navigation device”.
But I think it is a good idea to add type prefix in Garmin ShapingPoint GPX.
I do not know how other devices handle ‘sym’, ‘desc’ or ‘comment’ entries - perhaps a TomTom user or a user of an other navigation device can check that.
But I am sure that they show the name - so a name prefix will be shown.
In Garmin Shaping point gpx route export both Start AND Finish by the extension are Via Points.
Would propose to indicate identical and uniform or also in the standard gpx export use type Via.
By the way…does it hurt to include type tag in Garmin Shaping point route gpx export ?
Zumo Tester ? Rumbrummer ? Attached “All in one file”. All in one.gpx (7.1 KB)
Manual edit: Import Mapsource & Kurviger was both ok.
Kurviger: Prefer Shaping & Via by type to be exported by default…= no extra user menu item.
icons are typical icons for that point types ( I think ‘sym’ and ‘type’ tag are ignored by Navigator 5 )
Names of route points appear (also destination name ‘Aankomst’, not german ), also info shaping / via point (but I am quite sure: based on content of ‘extension’ tag)
Forgot to take screenshots, track matches the route path on screenshot above (magenta line). I think content of ‘trkpt’ tags is ignored, only coordinates ( ‘lat’ / ‘lon’ attributes ) used.
Nice ! It seems no negative surprises.
Waypoints: Does the Zumo display both (poi) wpt’s ?
Track: Normal display so 100% compatible as expected, even with the many extra elements attached.
Route: The name tag from gpx base is effectively used in the Via and Shaping Points without negatives by the attached info by type (ignored) so perfect.
It seems no cmt nor desc display as you did not mention the family name of James.
In picture find what is included in the (rte) route. Tnks for the report.
I did not import the waypoints - from my point of view importing the route points as waypoints is useless.
But I can check if someone is interested - but I do not expect problems caused by a ‘type’ tag.
To make it consistent and simply (KISS) uniform with the Garmin mode ( by extension)
Start and Finish indication so by the type Via. (As in the above example picture)
In actual (Beta) indicated by type Start and type destination.
The import works, 2 WPs have been imported.
WP “BOM” has an “i” as Icon, so tag ‘sym’ seems to work.
WP “Kapel” has the default icon - symbol “church” seems not to exist in N5.
Tags ‘cmt’ and ‘desc’ seem to be ignored.
I have a Tourer abo as i was hoping to get a seamless workflow from planning the route on the kurviger website and be able to generate a gpx file to export to a Garmin Zümo XT. Export and import works and the waypoints are transferred, but the waypoints do not keep the names that are visible on the website.
