2 error scenarios on the iPad
Hello Kurviger Team,
I am currently experiencing two different error situations with the app on my iPad from time to time. Both occur regularly, but are not reliably reproducible:
Error 1:
I split an existing route. After selecting the first and last point of the „new“ route and confirming, the app frequently gets stuck calculating and doesn’t recover. I can close and reopen the app, and my desired route is then displayed directly.
Error 2:
I view the info for a route, click on the info for tunnels, unpaved roads, closures, etc. I swipe the info display dialog down and then have no buttons left at all:
Once again, my only option is to close and restart the app. Functionality then returns to normal.
Here is the debug info:
Perhaps you can reproduce and fix this.
Best regards,
Marco
Sounds similar to this one:
Though I only have this on the iPad. On the iPhone, I can’t trigger either error.
Hi @Marco_R,
I can reproduce bug 1. Thanks for reporting, we’ll take a look. :+1:
I can’t reproduce bug 2 like this. Does it still happen after clearing local data? Does this always happen when you swipe down on the route details?
Hi Kira,
no, that doesn’t happen every time. But every now and then. I’ve cleared the local data a few times in between, but if it helped, it didn’t last long.
And this is the only dialog where this behavior occurs.
Marco
Yeah, I suspect this will be the same bug, so it should be fixed with the next update :slight_smile:
