3 dots menu and function location
Hi all, in a browser on a laptop/PC can we have the 3 dots menu that is only available in the “Plan” screen available on every screen. I like to using many of these functions from other sceens.
Place the
next to
Profile
Currenly you need to go back to the plan screen to Snap locations, view Turn Instruction, Save etc
The design keeps getting better. Nicely done.
OME
Thanks for the proposal. I just tried to reproduce your request - most of the 3 dot menu actions (honestly I would say all) are planning related:
May you be a bit more precise which of them you need in other kurviger screens and what is the use case?
I will be in planning mode that’s true. I will be adding Waypoints and often will Save, Snap to Street (there is a key shortcut for this), show entire route and turn instructions to see distance between stops for each nights stay so it is that from the detailed planning waypoint dialogue screen I need to click Plan and then the 3 dots - there must be an official name for the 3 dots ?? Hamburger? - the function I want.
As an additional thought can we have a short key for;
Save
Show entire route
Turn instruction
There is hotkey for save as well, but it currently only works in the planning view (Ctrl + S / /Apple + S). We need to add this hotkey to symbol to the … menu.
We call it the … or 3 dot menu :smiley: - I think the official naming for this is kebab menu, but that leads to people not knowing what it means.
Hamburger is the 3 - icon.
We do also have a save icon on the planning screen, so you don’t need to open the … menu.
I do agree that at least having the hotkey ctrl+s to work on other screens as well would be nice.
Regarding your actual request to place the … next to the profile, I think this might not be a idea. As this menu belongs to the route planning and does not provide infor for search, cloud, or profile. I do get your idea and having to switch to the plan screen is not that comfortable, so the hotkey could be a workaround.
Note: With ESC-Button you always go to the planning menu.
