Always show small roads
I really like everything about kurviger.
I use the “follow me” future alot when im out scouting for new small roads, preferably gravel roads. Alot of the roads are visible when i drive around 50kmh but when i go faster the map zooms out and only the " bigger" roads are visible. Is there a setting to always show all the roads?
Hi @Marcus_Moll,
There isn’t a setting like that right now, but you can turn off auto-zoom and use the + and - buttons to set a custom zoom level that suits your needs. Go to Settings and disable the auto zoom under the navigation category.
Thanks for the reply
Ok that kinda helps a bit. But it would be nice to have the future to always se all the roads. When you max zoom out, the map covers a big area and its easy to see the “small roads” if they are a dead end within a kilometer or two
I have the same wish. At least 2-3 zoom levels higher, the smallest streets should be visible.
