since I updated my pro version of Kurviger to 1.7.3, the app doesn’t start up anymore! The only thing that happens is that the screen turns white, and then the app fades out again. The same happens with the shareware version which I tried after I noticed this failure …
Greets
Etti
… no, there was nothing like an error report, the app just doesn’t start…
… and yes, I uninstalled and reinstalled both, the Kurviger Pro and the Kurviger sharware version, no changes, both do not start at all and do not give any messages …
When I downloaded an older Kurviger shareware APK (Version 1.6) and installed it, it worked flawlessly.
It would be ok for me to have this old Pro version running for a while, but 1. it doesn’t solve my problem and 2. I don’t know where I can get the Pro APK Version 1.6 .
Last but not least I can’t definitely say, which version I had before the last update of Kurviger Pro (1.7.3), but the version I had worked fine in January, so I gues it has something to do with the last update version of Kurviger.
the last running version on my mobile definitely was version 1.7! (I had a look at my last backups and it shows me the installed version of apps.) I tried the 1.7 Kurviger shareware app, an it runs smoothly …
So there is an issue with the step from 1.7 (running) to 1.7.2 (not running) …
That’s very unfortunate and quite difficult to debug without any report…
If you don’t have a newer device to use the app, we can offer a refund, see here for the details.
Android fragmentation hurts all of us and we’ll have to reconsider anyway the min version requirements in order to continue providing a seamless experience.
… never change a running system …
… and no, I don’t want a refund, I just wanted to support a very interesting development …
Possibly I should take the chance to upgrade my system, but will it solve my problem? Maybe it’s a hardware problem, who knows … I’ll have to think about it …
There are two sides to this. While on one hand, an update could decrease the performance of your device, on the other hand it will usually increase its security. Android 4.2.2 was released in 2013. 5.1.1 was released in 2015. Also many apps nowadays won’t be available for Android 4.X anymore.
It might. We are not sure why the app doesn’t work on your device. We can’t reproduce the issue. Chances are that the issue is the old Android version.
you’re right! I’ve updated my Android to version 4.4.4, and everything’s alright now, both the shareware as well as the pro version of Kurviger work fine! Now I will do the full step and take the last available Android version, I will see what will happen then.
As I said before, never change a running system, but if there’s an issue, you should act!
I wholeheartedly disagree and I am kind of worried for your - and possibly your family’s - internet safety. You do update at least your browser and stuff, right?
