[Android Auto BETA] 3.5.4 Feedback
This is the feedback thread for Android Auto BETA of the Kurviger Android App update 3.5.4. We are looking forward to your feedback!
Please note, Android Auto is unfortunately not a screen mirror. Google is very restrictive about what apps can show on the Android Auto screen. This means that at least for now, we are not able to implement every feature that is available in the regular app in Android Auto.
Android Auto is still considered BETA and we are working at full speed to improve Android Auto, please let us know if there are any issues.
Dies ist der Feedback-Thread fĂĽr die Android Auto BETA des Kurviger Android Update 3.5.4, wir freuen uns auf eure RĂĽckmeldungen!
Bitte beachtet, dass Android Auto leider keine Bildschirmspiegelung ist. Google ist sehr restriktiv, was Apps auf dem Android Auto-Bildschirm anzeigen dürfen. Das bedeutet, dass wir zumindest vorerst nicht alle Funktionen, die in der regulären App verfügbar sind, in Android Auto implementieren können.
Android Auto befindet sich immer noch im BETA-Stadium und wir arbeiten mit Hochdruck daran, Android Auto zu verbessern. Bitte lass uns wissen, falls es Probleme gibt.
Hi, I’m using Android Auto with a carpuride 502. My device has not automatic screen light adjustment so, at night (expecially when raining), the light from the screen it’s very disturbing and dangerous.
During night, even with dark mode on the phone, the kurviger app has a darker theme but on AA the map is still the same bright one. This is a common problem with other apps, the only app with a solution is Magic Earth, i think the solution is changing the map theme within the app itself (you have to choose day and night theme in the app settings. It also changes to dark theme when you drive under tunnels. I think Magic Earth too uses open street maps, so the tunnel information is present on this kind of maps. Maybe you can think to implement this functionality for the future. Best Regards.
We are planning on making this configurable in the future in our app as well.
In the meantime, there is a setting in Android Auto. In the Android Auto menu, open the “settings app”. You will find a setting for map design (light/dark/automatic).
Hi, I know of the setting but it seems to not work on the carpuride. It’s an issue with all the apps. Only work around is the dark theme imposed by the app.
Thanks for your reply.
Hi, after yesterday evening ride, with kurviger navigation, this morning i started mi ride to work and kurviger started with yesterday route and there is only the navigate and search options. I didn’t want to navigate to work but follow mode will be the best solution to have the map with velocity and (maybe) the speed limit of the actual road. I was already riding and late, so i didn’t want to stop and operate on the phone. Is there the possibility to ave search, navigate and also follow mode, to pick on the screen?
Another question :slight_smile: I have a bluetooth keyboard (barbuttons) to zoom and pan on the phone screen. This works using the phone but not on AA, with your first AA beta there was a bug that activate the screen on the phone while using AA, in those occasions the barbuttons was working also in AA because it was moving the phone while moving the AA screen. Maybe there is a work around to let use a bluetooth keyboard on AA. Who knows…
Thanks for your time.
Thanks for the proposal, we can certainly have a look what can be done in the future :+1:
We have remote controls also for AA on our todo list, that is something we will look into in the future :slight_smile:
Hallo, ich habe einen Bericht gelesen, das Android Auto für mehr Apps geöffnet werden soll. Betrifft dies auch die Darstellungsmöglichkeiten? Ich finde es echt schwer dazu im Netz was zu finden
Ich vermute da ist noch nichts Offiziell bekannt. Die Info klingt erstmal gut, bin gespannt wie das umgesetzt wird. Ich vermute die weiteren Kategorien werden extrem eingeschränkt sein, also Video-Streaming wird nur funktionieren wenn das Auto geparkt ist etc - schauen wir mal.
Hallo Freunde.
Ich hab echt noch nicht viel Testen können, finde das Android Auto Thema aber sehr spannend. Bis jetzt habe ich immer mit dem Handy Navigiert. Jetzt habe ich mir für die nächste Saison ein Display für Android Auto geholt. Ich bin echt gespannt. Also erstmal danke für eure Mühe. Eins ist mir aufgefallen. Die Größe der Textboxen. Es ist hier vielleicht schon diskutiert worden oder Google lässt eine Änderung nicht zu. Aber wie auch immer, ich finde die unnötig zu groß. Es wird zu viel Karte von der Box überdeckt.
Aber macht weiter so.
GruĂź, Nico
Genau, das haben wir hier schon diskutiert :slight_smile:. Google lässt keine Änderung an den Boxen zu, wir können weder Schrift, Schriftgröße, Box-Größe etc. ändern. Das kann nur Google bzw. eventuell der Hersteller des Android Auto Geräts indirekt über die Gerätespezifikationen.
Ok. Mal schauen ob die noch was machen. Danke fĂĽr deine Antwort und weiter so. :+1:
GruĂź, Nico
ich finde die Größe der Boxen gut - wollte ich nur kurz anmerken - ohne Brille macht das so mehr Spaß.
Moin!
Ich habe die Kurviger App (auf Samsung Galaxy) jetzt auch mal mit Android Auto (VW T-Roc) ausprobiert.
  1. Obwohl ich am Smartphone die Ansagen stumm geschaltet habe, textet mich das Auto voll (und unterbricht die Musik). Wie kann ich das ändern?
  2. Wie kann ich das Routing beenden?
  3. Nach jeder Route werde ich gefragt, ob ich die Route speichern will usw. NEIN ich will das nicht. Wie kann ich das dauerhaft abstellen?
    Dank & GruĂź
Komisch, eigentlich sollte auch die Einstellung vom Smartphone ziehen. Falls nicht kannst du in AA oben in der Leiste auf den Lautsprecher klicken um zwischen stumm/laut zu wechseln.
Wenn du in selbiger Leiste auf das x drĂĽckst, dann wir die Navigation beendet.
Du kannst die Aufzeichnung automatisch verwerfen lassen, das geht in den Navigations-Einstellungen.
