[App] Kurviger App Beta 3.1.X
We are happy to announce that we released version 3.1.0 of the Kurviger Beta App.
This update comes with several changes and improvements:
  • Pricing: Release of Kurviger Tourer+.
  • Pricing: Enforce premium features, you need to have an active subscription to use the premium features.
  • Navigation (App): Starting the navigation off route has been improved, you can now select where you want to start.
  • Navigation (App): Starting navigation close to the route has been improved.
  • Navigation (App): Via points are easier marked as visited.
  • Navigation (App): If no via point is ahead on the route, we only show time and distance to the destination.
  • Navigation (App): Short greeting is spoken when starting the navigation, this can help to identify issues with text to speech.
  • Navigation (App): Fix an issue where reducing the volume of other apps was not properly reverted after instructions.
  • Navigation (App): Fix rounding of distances when getting close to a turn.
  • Map: Improved contrast of the map, make it easier to see hills on the map.
  • Map: Reduce number of shown POIs on lower zoom levels. This should make it easier to spot more relevant POIs.
  • Planning (App): Don’t allow exporting empty GPX files.
  • General: Improved French translation.
In order to keep this thread clean, I would like to ask you to provide feedback in the discussion thread for the release . For specific issues or feature requests, I would like to ask you to create a separate thread. You can find more about the current BETA state in our documentation. It might take a few hours until the new update shows up in Google Play.
Thank you very much for your support. We are looking forward to your feedback :motorcycle: :partying_face:
Wir freuen uns, euch mitteilen zu können, dass wir Version 3.1.0 der Kurviger Beta App veröffentlicht haben.
Dieses Update bringt einige Änderungen und Verbesserungen mit sich:
  • Preisgestaltung: Veröffentlichung von Kurviger Tourer+.
  • Preisgestaltung: Um die Premium-Funktionen zu nutzen, benötigst du nun ein aktives Abo.
  • Navigation (App): Das Starten der Navigation abseits der Route wurde verbessert, du kannst jetzt auswählen, wo du starten möchtest.
  • Navigation (App): Das Starten der Navigation in der Nähe der Route wurde verbessert.
  • Navigation (App): Zwischenziele / Via-Points werden leichter als besucht markiert.
  • Navigation (App): Wenn kein Zwischenziel / Via-Point vor dir auf der Route liegt, werden nur noch Zeit und Entfernung zum Ziel angezeigt.
  • Navigation (App): Beim Starten der Navigation wird eine kurze Begrüßung gesprochen, die helfen kann, Probleme mit der Sprachausgabe zu erkennen.
  • Navigation (App): Es wurde ein Problem behoben, bei dem das Reduzieren der Lautstärke anderer Apps nach den Anweisungen nicht richtig rückgängig gemacht wurde.
  • Navigation (App): Die Entfernungen von Abbiegung wird nun genauer dargestellt.
  • Karte: Der Kontrast der Karte wurde verbessert, so dass Hügel und Berge auf der Karte besser zu erkennen sind.
  • Karte: Reduziere die Anzahl der angezeigten POIs auf niedrigeren Zoomstufen. Das sollte es einfacher machen, relevante POIs zu erkennen.
  • Planung (App): Exportiere keine leeren GPX-Dateien mehr.
  • Allgemein: Verbesserte französische Übersetzung.
Um diesen Thread aufgeräumt zu halten, würden wir euch bitten,Feedback im Diskussions-Thread für diese Version zu geben. Bei Anfragen oder Problemen zu einem speziellen Feature würde ich euch bitten einen extra Beitrag anzulegen. Informationen zum aktuellen Beta-Status findet ihr in unserer Dokumentation. Es kann ein paar Stunden dauern bis das Update in Google Play angezeigt wird.
Vielen Dank für eure Unterstützung. Wir freuen uns auf euer Feedback :motorcycle: :partying_face:
7 « J'aime »
