How does kurviger compute the average speed calculations? I am taking a route across a dirt road and it seems rather slow. It’s not a terrible problem because I can re-calculate it in my head! I was just wondering now if there is a way to change it at the moment it calculates the average speed at 10km/h! approx.
By the way although not intended for this purpose kurviger is an excellent application for planning pre existing routes off-road. I have been doing this with considerable success for some time.
Yes this is correct, for offroute roads Kurviger currently assumes a low speed. As Kurviger currently has no desginated offroute mode. Currently it’s not possible to change this, but as you said, if you know you do on average 40km/h you can do the math yourself.
As make a wish function I would also like to be able to calculate the route duration on the basis of a user-defined average speed, which can be changed as an option. In addition, the calculated average speed once with and once without breaks as a statistical value per trip (the app should then automatically stop the calculation of the average speed for the value without breaks when stopping).
