I’m using Kurviger with android and an induction power supply on my bike.
The challenge is that Kurviger is using so much power that the power supply (techno globe induction) is in trouble and overall battery percentage is slowly decreasing.
It’s not an issue with my phone, nor with my power supply : when using Waze, same bike, same roads… Battery is loading fast.
Would it be possible to optimise battery usage?
Regards
Hello and what power does the charger have?
Basically we are working on improving the power consumption but that may take some time. Significant improvements have already been introduced in the last few weeks and with a suitable 15 watt charger this works very well.
The power is 10w. But once again, while using Waze instead of Kurviger, battery is loading fast.
When using Kurviger, CPU consumption is higher so that charger isn’t able to compensate.
Kurviger simply needs a little more power and 10 watts is too little. Of the 10 watts, significantly less reaches the smartphone and the rest dissipates as heat.
However, Kurviger wants to further reduce consumption as far as possible.
10 watts is very low for a modern device. I am using this with no problems,
