Taking current closures into account
Hello Kurviger users,
I had a minor issue during my last tour. I planned a route through the Czech Republic and Poland (Krkonoše / Riesengebirge) and used Kurviger for navigation. When I reached Vysoké nad Jizerou, the road was closed due to construction work. I followed a local detour, and everything was fine.
Afterward, I checked the route to figure out why Kurviger didn’t reroute me. I checked TomTom, and the road closure was listed there as well as on the Kurviger map. However, when I reload my route, it still guides me through the construction site. Strangely, if I plan a new route just from the entry to the exit of the town, it correctly routes around the closed road. Rerouting is enabled in both cases.
I would like to share the Kurviger Tour. But it starts at my home and as soon as I change it, the tour is different or it recognise the construction site. :person_shrugging:
The warning in Kurviger about a closed road is near my home.
Any ideas what can cause this?
The picture shows no road blocks, the red line is just a overlayand picture 1 to 2 has a changed curviness.
When you load a route, there is no automatic recalculation! It just loads as planned. You can try by loading the route and move a single point a little bit. Then recalculation should be done and the block is avoided - yes?
My idea about this is, that the road block did not exist, when you planned. Then you drove 100% exactly as planned, no deviation from the route and therefore no recalculation at all? This way Kurviger had no knowledge about the road block.
A guess.
You are wrong and right. I know that it is an overlay. I did it to show the route I drove.
If I turn off the auto-rerouting function, the road closure becomes visible on the map. And you’re right—the closure was published on the exact day I started my tour, whereas I had planned the route the day before. Just bad luck, I guess!
I am not a fan of loading a route with no recalcuation. But yes, probably bad luck, a rare case and you managed it.
Please explain it to me. I thought that when I load a planned route from the cloud, the app would take a new potential road closure on the route into account. How can I trigger a recalculation?
Regards, Nico
  • load the route
  • make any change (e.g. move a shaping point, add/delete a shaping point) to force recalculation
Ok. That works. I didn’t know that.
But that would be a great feature, when you get an note about road blocks while you load the route.
Alternatively, tap the “i” button after loading the route and then recalculate:
I am unsure about this. This red info appears - as far as I remember - only when you have a very old route - before the change of this behaviour, as the file format had to be changed? So in this case recalculation plus saving is required to save in the new file format. Possibly something is mixed in my brain.
This the thread, long ago. Kurviger Routen nach Laden aus der Cloud (App und Web) geändert
Robin also proposed to execute Snap waypoints to route.
It is definitely not limited to routes saved in old format. I have routes that are roughly one month old, and show the red dot on “i” with the hint for recalculation. I do not know the condition when the warning will be issued - probably some time threshold.
That works also. But it also changes the route a lot.
I this case it’s necessary to use much more shaping points to keep the original route in shape.
Hi @Nico,
We think so too. Currently, you get a warning that your route might be outdated when you load an old route from your cloud to which that might apply - e.g. there are new current road closures in the data.
We plan to improve the whole behavior regarding route information and the respective warnings in future. Especially regarding current road closures.
So thanks for the feedback!
:+1:
