Beta program
I’ve also installed the Beta version. I was wondering which functionality is in the Beta version compared to the Pro version. Or is it just a version that is bug fixed compared to the official version?
Thanks in advance.
I’m not sure, but planning Mode in landscape… As an example.
You can try to compare, or ignore, i am using always the Beta. It works fine.
Yon can check the change log to see what is new in each version.
BETA version preceeds the official release and gives you early access to new features. BETA version has a lower maturity compared to the official release, and if you choose to use it, you accept that there still might be some limitations and minor bugs. Should you discover some shortcomings of the BETA, it is helpful to post it on the forum so that developers can investigate and fix it before the official release.
