Bug Report - Route through Military Training Area
[EN] I read the corresponding [documentation]
[DE] Ich habe die entsprechende [Documentation]
Yes
[DE] Beschreibung des Problems und wie es anstatt dessen funktionieren sollte:
“Military Controlled Areas” or “No Acces Zones” in general could be detected by the Software and no routing through this areas should be allowed.
Mit freundlichen GrĂĽĂźen / Best Regards
DaPaulus
FYI: I checked if the Area is marked correctly turns out it is.
access = private
DaPaulus
Thanks for reporting this. Kurviger and many other route planners based on OSM data don’t evaluate tags on polygons (rather tricky process).
For example see:
The best way to fix this would be to add access=private to either the roads in the area or maybe to fences / barriers that might be placed on the road there.
OK Thanks for the Reply.
I adjusted the Road Access Qualifiers in OSM.
