Carpuride W702P - Error: read property ‘type’ of undefined
Hi Kurviger Team,
I am contacting you because I am experiencing an unrecoverable crash in the Kurviger application when attempting to download maps for offline use directly on a standalone Android motorcycle screen (Carpuride W702 Plus, running native Android 12, with 4GB RAM and 64GB internal storage).
Every time I try to initiate a map or region download within the app, a continuous red error popup appears on screen:
Message: Uncaught TypeError: Cannot read property ‘type’ of undefined - URL: undefined - Line: 2 - Column: undefined - Error object: {}
I have performed the following troubleshooting steps without success:
  1. Verified a stable Wi-Fi connection.
  2. Performed a complete app data wipe and cache clearance from system settings.
  3. Granted full storage management permissions (“Allow management of all files”).
  4. Checked that storage path selection fails due to system folder mapping limitations on this device.
  5. Attempted downloads using smaller regional map files.
The issue persists and appears to be a compatibility bug with the WebView / JavaScript libraries used by the app’s download manager interface on this firmware.
My goal is to use the app 100% standalone on the motorcycle screen without relying on a smartphone. Is there a technical workaround, patch, or previous APK build that resolves this variable reading error in the map manager?
I look forward to your guidance and have attached a screenshot of the error.
Best regards,
Jesús
Hello Jesús and welcome to the forum!
If you suspect a Webview problem - have you tried updating the webview?
Also, please go to the bottom of the settings menu, copy the debug info and post it here. That would give developers a better idea about your configuration.
We only have the a Carpuride Plus running Android 14. With Android 14 it worked for us to download offline maps. Could you check if an OS update is available for you?
We are pretty sure this is due to the old Webview used with Android 12. If you can update to 14 or update your Chrome version, that should fix the issue.
Hello Kurviger;
I have installed the app onto a Carpuride 702 Plus which is running Android 14 as an operating system. The map in the background never loads and when I go to open a saved route from the cloud I get this message “Message: Uncaught TypeError: Cannot read property ‘type’ of undefined - URL: undefined - Line: 2 - Column: undefined - Error object: {}”
I have uninstalled and reinstalled the app, I have logged in and out. Everything is working fine when I log into a pc and on my iPhone. I have cleared the cache and deleted the locally saved data which seemed to restart the app as I had to log in again. I have a good internet connection at the house in the garage and I have tried using my phone as a hot spot. Other apps work fine and I can go online with the unit and everything seems fine.
What is this fix for this please?
Please give this information. Interesting is the version of the webview. You can use above link “Webview” from @t00thl355 to see if there are updates. Should be some version above 150.
Here from my phone.
OSM-Datumsstempel: 29.10.2026
Version: 3.6.7
Device: motorola - moto g53 5G - Android: 14 - WebView: 156.0.8078.47
App-Version: 3.6.7 - 8004
Screen: 412 x 915 px - 1.75dppx
Interesting to read the initial information about the Carpuride 702 Plus (standalone Android, no smartphone required).
I have a question about the installed Android:
According to the Carpuride website, Android version 12 is used.
Unfortunately, this Android version is no longer supported, and there are no more updates or security patches.
Do you actually have Android 14 on your device?
We have a Carpuride Plus here for testing, and the device is running version 14.
I use a Carpuride W702 PLUS to run the app autonomously on Android. After some hickups it finally worked great.
Untill I had a hardware problem and received a brand new Carpuride device.
I installed the Kurviger app on this new W702 PLUS device, it it repeatetly shows 2 error messages whenever the app tries to get information.
What is the problem and what can I do to solve?
Grtz,
GV
Your Webview version 91 seems to be too old. See this thread how to update. Please let us know, if this solves the issue - many thanks!
If this does not work, you could also try to contact carpuride. OTA Update
YES!
Could not find Webview among installed apps. Went to the store, tried to install. Appstore switched to Update…
Few seconds later, all solved.
Plan-modus got covered in screen by the side bar from the operating system. Anoying, but i don’t use the planner sitting on the bike.
Navigate modus runs okay.
Thanks for the help!
Perfect :+1:
We are actually looking at these things right now, so this should be solved with one of the next updates.
Just an “unfriendly” idea as you are so friendly to give immediate feedback :+1:. No must at all.
Perhaps somebody did already and can give hints?
Robin reports that he has - as I understand - the same device, but with Android 14, while others are reporting as you, still beeing on Android 12. Have you checked if there is an update available for your device? If not, would it possible to contact Carpuride as a customer to ask how to update (as I proposed above with Link to OTA update)?
The exact version of the Android is niet entirely clear to me;
In the information-panel in the setting area of the Carpuride there’s clearly ‘Android 14’ shown.
However in the debug-area of the Kurviger-App it shows Android: 12.
I can’t show the screenshots, since the device is not connected at the moment.
Grtz,
GV
Thank you. Your Webview 91 was about 2021, would fit Android 12 about 10/2021. Android 14 is about 10/2023 (Wikipedia). Strange. I just decided to believe Kurviger.
Hi, I have the same device, CARPURIDE W702 PLUS, mounted on my BMW last week, and I get the exact same error in the app — I was just about to report it.
All my device updates are installed and it is definitely running Android 14. Is there anything I can check to help you troubleshoot?
Yes, please install the latest version of Chrome (alternatively Webview) from the Play Store, then it should work, see:
If that doesn’t help, please let us know again
Yes. Check WebView (see post Carpuride W702P - Error: read property ‘type’ of undefined - #10 by Toffel) and post debug info:
This should also work:
Android Settings > Apps > Show all apps > perhaps then 3-Dot > Show system apps. Then search Android System Webview.
Here from my Moto G53/Android 14.
