It would be nice, if map-styles could be changed by shortcut (e.g. Esri Street: alt+x, Esri satellite: alt+y).
Interesting idea, do you change them that often? Would others like to use that as well?
For me, it’s not worth setting up a shortcut - but of course it doesn’t disturb in any way.
Yes, in detail planning I often change between Esri Street an Esri satellite, e.g. to seach a nice place for a stop.
Ok, I can add this to the todo list and see if this can be done, I am not really sure this will work though, as this would require either many shortcuts or a shortcut using the arrows to switch through the list. Not a high prio item on the list for now though ![]()
That would bei great. Thank You. Perhabs the shortcut could be realized by using the numeric keypad.
Yes, I thought about something like this as well. The biggest issue is that browsers have already many hotkeys build in, so we need to check they don’t intersect.
