e is undefined
User Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/114.0
Cookies Enabled: true
Screen: 1680 x 1050 px - 1dppx
Can you provide more information about this error? Can you reproduce this error?
Hello Robin,
Yes, the error message can be reproduced. It appears if I try to make any inputs in the screen area “Planung” (planing?). I have to press “calculate the route” or “reload the page” to see the correct result of my input. It happens only if I use the Firefox Browser, no error with Microsoft edge, but I don´t want to use Edge.
Any idea?
( I tried to insert a screenshot ;-( not a good idea, I suppose? )
I can only reproduce this, when I setup Firefox in the strictest setting to block all cookies (also see the warning from Firefox, that this will actually break websites). Are you using this setting?
Ok ! This was very helpful, I changed the settings and everything is working now.
I was a little bit confused because there was no warning coming from the Kurviger WEB side concerning this issue. And “e is missing” is a message I did not understand
Thanks a lot ! Problem solved …
Greetings from Bavaria
