Error on map - Italy - Genoa
Not sure if that is the right place and way to report a uncorrect match on map, so sorry in advance if i’m wrong.
I found an error at 44.409068, 8.9036036, Italy, Genoa, access ramp to Strada Aldo Moro, looks like it’s marked as “in construction” in red dotted line. Actually, is the old ramp, and is still available to access Strada Aldo Moro, AKA “Sopraelevata”, from Elicoidale San Benigno.
Due to the “in construction” is non available on map for navigation.
That’s for OSM to fix.
You can add a note about the issue here. No account needed.: New Note | OpenStreetMap
Done, thanks so much for the hint
I tagged it in OSM, should work in Kurviger in a few days
Works:
https://kurv.gr/VAHkA
