Hi there
I have no problem, planning and exporting the route via gpx and other formats. The same applies by using exporting to other devices in general.
Very often I make use of the export to device (CRN) and I’m using mainly the function add intelligent waypoints. Once exported to and imported in CRN it seems to be that the intelligent way points are Via Points. And in my opinion this is a disadvantage because I would prefer shaping points to be exported instead.
Reason is clear, once a navigation is running I have to skip every intelligent waypoint if I do not want to follow the route as designed.
From my perspective, it would make life easier if you could export shaping points or at least offer us the selection either way in the intelligent export function.
Thank you for your attention on this matter.
Peter
