DE: Deutscher Text kommt weiter unter
Dear fellow Kurviger users,
as discussed in the old forum here and partly in the new forum here, Kurviger needs an export for Garmin’s customized GPX format.
Thanks to everyone that contributed their knowledge, hints and tips. Special thanks go out to Heinrich Wack and @rumbrummer for providing feedback and detailed information.
The current version is released as BETA, this means that there is still some room for improvement, please let us know if you miss anything or if something does not work as expected. Currently, this feature is only available on the website and not in the app. This feature will be added to the app soon. This feature is now available in the app as well and is no longer considered BETA.
How does it work:
The start and destination (first and last waypoint/via-point) are placed as a waypoint with alarm / via-point. Every point in between is placed as waypoint without alarm / ShapingPoint.
What does this mean:
When loading a route from Kurviger into your Garmin device (or Basecamp) the route will be recalculated. Therefore we recommend to export the Route & Track after importing it, you will see the calculated route and the track. It is possible that there are some deviations between the two, exporting Route & Track will help to identify these deviations easily. We recommend to export a lot of additional waypoints (Stützpunkte) to reduce the deviations as much as possible.
Things to watch out for:
When starting the navigation, you should be on the route already. If you are not on the route, your Garmin will recalculate the whole route from your current location to the end, ignoring all ShapingPoints. We recommend to disable the recalculation of the route. If you want a perfect representation of your planned route, you still have to use Basecamp, the Kurviger export should work well enough without Basecamp, but there could be deviations.
If you don’t want to convert all waypoints into ShapingPoints you can still use @rumbrummer’s converter, here.
Let us know how it works for you ![]()
Cheers,
Robin
Hallo liebe Kurviger Nutzer,
wie bereits im alten Forum, sowie auch im neuen Forum besprochen, benötigt Kurviger einen Export für Garmins angepasstes GPX Format.
Vielen Dank an alle die uns bei der Entwicklung geholfen haben. Ganz besonders möchten wir uns bei Heinrich Wack und @rumbrummer bedanken die uns mit Rat und Tat zur Seite gestanden sind.
Die aktuelle Version wird als BETA veröffentlicht. Das bedeutet, dass es noch ein paar Möglichkeiten gibt das ganze zu verbessern, hier ist eure Mithilfe essenziell. Der Garmin Export ist aktuell nur auf der Webseite verfügbar und nicht in der App. Die Funktion kommt aber bald auch für die App. Die Funktion ist mittlerweile auch in der App verfügbar und ist mittlerweile nicht mehr in der BETA Phase.
Wie funktioniert das Ganze:
Der Start und das Ziel werden als Wegpunkt mit Alarm / ViaPoint angelegt. Alle anderen Punkte werden als Wegpunkte ohne Alarm / ShapingPoint angelegt.
Was bedeutet das:
Beim Laden der Route aus Kurviger in dein Garmin (oder Basecamp) wird die Route neu berechnet. Daher empfehlen wir den Export von Route & Track. Dadurch lassen sich Abweichungen der Garmin Route zur geplanten Route einfach feststellen. Wir empfehlen den Export von vielen Stützpunkten um diese Abweichungen so gering wie möglich zu halten.
Darauf solltest du achten:
Beim Start der Navigation solltest du dich bereits auf der Route befinden, ansonsten berechnet dein Garmin Gerät die Route bis zum Ziel ohne ShapingPoints (deine Wegpunkte + Stützpunkte) neu und das Ergebnis kann komplett abweichen. In diesem Zusammenhang empfehlen wir, die Neuberechnung zu deaktiveren. Eine perfekte Deckung von geplanter Kurviger Route zu Garmin lässt sich am sichersten über Basecamp erstellen, der Kurviger Export sollte aber auch ohne Umweg über Basecamp funktionieren.
Falls du nicht alle Wegpunkte in ShapingPoints umwandeln möchtest, dann kannst du weiterhin den Konverter von @rumbrummer verwenden.
Lasst uns wissen wie diese neue Funktion für euch funktioniert und ob noch etwas fehlt?
Lg Robin
