Hello, I have a problem with the export/import of planned routes in the format “garmin shapingpoint gpx” into the BMW Navigator 6. If I have installed the planned route in the navigator using a USB cable from the MAC and then call up the route planning after disconnecting the navigator from the MAC, the screen turns black and the device turns off. The route planning can then no longer be used even because the imported routes are removed from the device. Does anyone know the problem? Does anyone know a solution? The BMW Navigator 6 is the latest with an improved display and the latest software/hardware stand.
Are you sure that the battery of the Navigator is fully loaded?
Try to connect the Navigator with a power supply and double-check wether it’s fully loaded respectively >> give the device a bit time to upload the battery.
Did you copy the GPX file into the “folder GPX”?
How many recent files are in the Folder GPX?
Delete all files in the “folder GPX” which you do not need.
In fact you can delete everything in this folder except your needed GPX file!
