Export pour Google Earth 7
Bonjour,
La fonction “Exporter” existe déjà pour Google Earth 4 et 5 mais pas pour Google Earth 7.
Pouvez-vous la développer car je suis obligé d’exporter en “gpx” et d’utiliser ensuite un convertisseur externe ce qui me fait perdre beaucoup de temps ?
Merci
Hello @Biquet,
A .kml file exported using “Google Earth 4/5” in Kurviger should generally be importable in Google Earth 7 as well. Did you try this already?
Hello,
Yes, of course; I tried both, but it is impossible to modify the path afterwards.
Alright, so the transfer from Kurviger works but Google Earth doesn’t allow you to edit the route. In that case I’d suggest you edit the route in Kurviger then and transfer your route when you finished.
Hello,
Could a site administrator—or the person who developed the software—answer my question? You developed the “export” function for GE 4 and 5; is it really that complicated to modify it for GE 7?
Thanks.
Sure, I am able to import Google Earth 4 exports into Google Earth 7. It seems the GE5 format is not compatible with newer versions any more? Maybe you can check. If there is a particular issue, maybe you could provide more details?
Exporting with GE4 allows the track to be modified, but the “measurements” tab is gone, which doesn’t work for me.
Exporting with GE5 does not allow the track to be modified, but the “measurements” tab is present, which doesn’t work for me either.
This is very likely an issue of Google Earth.
With measurement tab, we are using a different element that is not modifiable. Without the measurement tab we are using an element that is modifiable.
Maybe you could provide some more details about your use case, so we could check if we can change anything.
Bonjour,
What detail do you need? I’m not quite sure what else I can tell you.
I mean, maybe you can describe what you want to do and maybe we can find a different solution for that.
Regarding the issue itself, I think this is by design from Google Earth.
