Hi @t00thl355
Thanks for your feedback first of all!
1.I can reproduce it, and agree that this is inconsistent. I imagine it was more of an oversight than intentional. I’ll have a look at this.
2. I think I mentioned this in another post: We’re not entirely satisfied with the menus in the cloud yet, and that’s definitely still on our list of things to address. I also think it should probably be easier to change a category though you only have to do this once per favorite. But I get it: if you’re creating multiple favorites and want to assign them all to categories, it’s a tiring process. But I find your suggested approach almost a bit too brief? You should not accidentally change a category, too.
3. This issue is also on the list. We can’t do everything at once, but we’ve already noted this point as feedback. It is still to decide what happens then with the favorite as the idea is that all data of the POI is synced. Regarding the menu order: see above (we’re aware of the issue with the cloud menus).
What should be revised here in your opinion? The left one counts the favorites in this folder. On the right, you can see how many items you’ve selected in the multiple-select list.
Although the number seems to be wrong in your case? Are you reporting a bug here? If so: can you reproduce it?
